heya ppl....
just wondering what I could paint in the engine bay (by myself)
is it safe to paint the engine block itself (just the top bit really)
any suggestion on type of paint
things i should keep in mind / look out for....
anyone done anything similar...pictures???
thnx
cheers
https://www.sau.com.au/forums/topic/360063-can-i-paint-the-engine-block/
try searching for 'painting cam covers' or 'painting' betalked about alot,you may even find a tutorial..
you can paint anything by yourself, your a big boy now..
suggestions are radiator top mounts (black), cam covers(almost any colour), alternator (siver or back), fuel rail (black, silver maybe a blue or red)
please dont paint a heap of the engine bay plastics in the same colour, it looks cheap
and possibly consider powdercoating it will look better and last longer.
and please dont use a crap bright colour and have the rest of the engine bay stock standard, again it looks cheap...
A can of spray paint and an engine bay can lead to hideous results in the wrong hands.
Also "the engine block" is something completely different to camshaft covers (which is what you are most likely talking about).
Yes every one has done something similar. Perhaps look here:
http://www.skylinesaustralia.com/forums/topic/289753-put-up-you-engine-bay-pics/page__st__120__p__5563239__hl__engine+bay__fromsearch__1#entry5563239
Using search goes a long way on these forums.
yeah some times less is more..
First time around i just touched things up a little. things that were silver got a thin coat of silver paint as did the things that were black and it looked good and neat..
Second time around i decided to coat everything thicker and add some clear to really make it shine, now the painted things look too good for the rest of the bay and it just doesnt quite sit right..
That and i managed to spew petrol all over my fresh cam covers and they are now f**ked.. :angry:
but before you paint anything get in there with a can of degreaser and a rag and clean everything up, no point painting things and putting them in a dirty bay
ahhh the old freshly painted part in the dirty stock engine by trick.... luv it...
what about leave everything stock and just clean it immaculately, looks awesome if your not going to have myriads of aftermarket parts or a completely done engine bay imo
unless your into track work thenjust have everything functionally clean
thanks fellas......
yeah i just used 'engine block' coz i have no clue of the technical terms for stuff...hahaha....hey im getting there..slowly :)
can of degreaser and rag it is then....
Il put up pics when I finish it..sometime day after hopefully
i painted a few bits and pieces....the bits where the strut bar is attached to...suspension cover thingies?? (sorry wat are they called)
im using only black as of now....NOT planning to go the colourful route...just want a nice tiday clean and shiny looking area
il put pics..n then i can explain why i want to paint and what i want to paint etc.....camera is on charge :)
cheers
thnx for the 'educating' btw...i learn new things everyday
hahaha
jeremy
I also found using metal polish on old metal parts work a treat too. I even went as far as sanding the rocker covers in 400 grade and took to it with the metal polish,im officially addicted to the stuff lol.
we shud meet...and you cud help me clean up my engine bay???? :thanks:
ok...so i cleaned it up best I could....with a cheap degreaser....
plan on doing it again with some better quality stuff....
see the yellow circled bits....thats whats annoying me....what do i do with them
oh n I cant remove things myself....so if you suggest take them off and paint them then where can I get that done??
(anyone in and around joondalup who wants to help :cheers: hint hint)
thanks anyway
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
