  • Replies 386
hi mate you wouldnt have a wiring loom hanging around would you?
I have the engine wiring loom but its cut from the car, do u need the complete loom or more so the actual plugs?
quick update of remaining parts with adjusted pricing on clutch & wheels + some new parts...
1. front door trims - $140
2. rear door trims - $100
4. front windscreen - $90
5. rear tail lights - $100
6. factory afm - $50
7. blitz icolor dual solenoid dsbc boost controller (with user manual) - $500
8. attesa 4wd pump - $180
9. hicas pump - $70
10.dash vent (passenger side) - $40
11.left cv with knuckle assembly - $80
12.right cv with knuckle assembly - $80
13.drivers side window/mirror control - $50
14.sun visors - $10
15.complete boot trim - $80
16.instrument panel surround (does not have headlight switch) - $20
17.power steering line - $10
18.caster (radius) rods - $40
19.radiator overflow bottle - $10
20.passenger & drivers side door sill garnish - $40
21.door seal finish - $10
22.factory side skirts (black) - $140
23.front subframe - $20
24.bootlid rubber seal (no tears) - $10
25.power steering reservoir - $10
26.passenger side window switch - $20
27.os giken triple plate clutch - $1400 PRICE DROP $1350
28.full set of nissan wipers - $50
29.2 x rb26 timing belts (have done less than 5000km) - $30 EACH
30.2 x rb26/30 timing belts (have done less than 2000km) - $30 EACH
31.front sway bar with linkages & brackets - $40
32.cometic metal head gasket (has done 30min of work) - $80
33.interior a/c control unit - $80
34.17" forged Work BRS Poison wheels with bridgestone tyres - $800 PRICE DROP $750
35.rear boot plastic trims which sit on the top of the rear tailgate - $40
36.momo gearknob - $50
38.factory rb26 harmonic balancer - $80
39.gearbox cross member - $30
hi mate how much for the tail lights posted to melb ? 3805
postage works out to be only $11 to 3805.
total price including tail lights is $110 to your door :)
How much for the under car surge set up and also do u have the front seats for sale pm me the price
Thanks
Seats are long gone.
Under car surge tank is a $1400 system with receipts, I want $700 for it. Done less than 2000km.
Update of remaining parts...the door garnish’s are back for sale as well as the bosch 044 fuel pump with factory cradle!
2. front windscreen - $90
3. rear tail lights - $100
4. blitz icolor dual solenoid dsbc boost controller (with user manual) - $500
5. attesa 4wd pump - $180
6. hicas pump - $70
7. dash vent (passenger side) - $40
8. left cv with knuckle assembly - $80
9. right cv with knuckle assembly - $80
10. drivers side window/mirror control - $50
11. sun visors - $10
12. complete boot trim - $80
13. instrument panel surround (does not have headlight switch) - $20
14. power steering line - $10
15. caster (radius) rods - $40
16. radiator overflow bottle - $10
17. passenger & drivers side door sill garnish - $40
18. door seal finish - $10
19. factory side skirts (black) - $140
20. front subframe - $20
21. bootlid rubber seal (no tears) - $10
22. power steering reservoir - $10
23. passenger side window switch - $20
24. os giken triple plate clutch - $1350
25. full set of nissan wipers - $50
26. 2 x rb26 timing belts (have done less than 5000km) - $30 EACH
27. 2 x rb26/30 timing belts (have done less than 2000km) - $30 EACH
28. front sway bar with linkages & brackets - $40
29. cometic metal head gasket (has done 30min of work) - $80
30. interior a/c control unit - $80
31. 17" forged Work BRS Poison wheels with bridgestone tyres - $750
32. rear boot plastic trims which sit on the top of the rear tailgate - $40
33. momo gearknob - $50
34. factory rb26 harmonic balancer - $80
35. gearbox cross member - $30
36. bosch 044 fuel pump intank setup with factory cradle - $100
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
