I have always wanted a midnight purple R33 GTR and i have now gotten a job that allows me the luxury of getting my (realistic) dream car
ANyway, i spotted this add on carsales
http://www.carsales.com.au/all-cars/private/details.aspx?R=9422832&keywords=r33 gtr&tsrc=allcarhome&__Ntk=CarAll&__Nne=15&__Dx=mode matchany&__D=r33 gtr&silo=1011&seot=1&__sid=12CAD7564957&__N=1216 1246 1247 1252 1282 4294963846 4294963593&__Ns=pCar_RankSort_Int32|1||pCar_PriceSort_Decimal|1||pCar_Make_String|0||pCar_Model_String|0&__Qpb=true&__Ntx=mode matchallpartial&Cr=0&__Ntt=r33 gtr&trecs=170
rang the guy, no answer or reply, then i discovered the same car on ebay tonight
http://cgi.ebay.com.au/Nissan-Skyline-GTR-R33-VSpec-/150588790611?pt=AU_Cars&hash=item230fca9753
msg'd the guy and asked why hte number and address had change, he replied saying that he's just bought it, but he's "decided its not really practical and also wants to get something a bit cheaper"
i reply asking if there is anything wrong with the car to come to the decidion to sell it so quickly, he replies
"its my only car, chews a bit of fuel and a bit annoying in stop/start traffic, not very practical,p if i could keep it as a sunday car i would"
Does this sound dodgy to you? should i steer clear of it?
Im a qualified mechanic, (currently a fitter) so have no dramas in being able to fault find anything with the car, but does anyone know of this car or its history, and obviously him being the new owner, he wont know its history like the old owner does, wont know all the mods, where it was serviced etc
on a side note, the biggest issue i keep coming back to about owning one of these is the maintenance on it and running costs, and the fact that i do 60kms each way to and from work along the M4, so is it a car that ill hate if i do constant driving in as well as dealing with the traffic everyday, am i better off getting a shitter runabout for weekly duties (id rather not)
http://www.carsales....32&keywords=r33 gtr&tsrc=allcarhome&__Ntk=CarAll&__Nne=15&__Dx=mode matchany&__D=r33 gtr&silo=1011&seot=1&__sid=12CAD7564957&__N=1216 1246 1247 1252 1282 4294963846 4294963593&__Ns=pCar_RankSort_Int32|1||pCar_PriceSort_Decimal|1||pCar_Make_String|0||pCar_Model_String|0&__Qpb=true&__Ntx=mode matchallpartial&Cr=0&__Ntt=r33 gtr&trecs=170
http://cgi.ebay.com....=item230fca9753
just on your side note i drive my 33gtr everyday to work on the M5 peak hr traffic in the afternoons and drives like a normal car and thats with an exedy heavy duty clutch, more time i spend in my car the more i love it
thats the reply i want!
im still gonna look at it on sunday, but very sceptical
what sorta power is expected from the setup it has too? nismo injectors, N1 turbos, intercooler, exhaust, Apexi PFC, and is it generally a reliable setup if not pushed too hard
as i drive past eastern creek everyday, i can see myself going there to try the drags and the track at least once, and when funds permit
Maybe he has bought it and then realised how much fuel they go thru....
tried justifying the car to the wife saying he will drive it gently and it will be fine and realised it aint....
If your a mechanic and know your stuff,give it the once over and if everything you see is good, he maybe genuine.....
Do you really want your 'dream' car to have that many kilometers on it? Its 16 years old man. I guess your a mechanic so you would know how many thousands of dollars you need to put on top to fix/overhaul certain areas.
Mate for 22k - spend another 10-12k and buy mine.
Full built motor, suspension, wheels, rebuild transfer case, clutch - the works ;)
Save yourself 10k (it'd cost you over 40-45k to build what i have) and walk away with a 370rwkw track ready/street warrior GTR without leb-spec modifications.
Would also save himself the head f**k of trying to get it right and time wasted doing so.
"If" the bug bites to modify it bites hard!.... as many will know.
Well, just dropped by to japlink and spoke to Adam for a while, he reckons he could import a 33 gtr Inc rego, compliance etc for 16-18grand, that's a series 2, not 3
Id like it to be a midnight purple with 18x10 (or 11"), suspension work, upgraded turbo setup and fuel system, decent driveline, basically all the mods you'd do to a streetable 300kw GTR, but so it still looks stock apart from wheels and a set of ganador mirrors and some carbon highlights
Still checking this local 33 out tomorrow, but might seriously consider importing one instead
you arent gonna be able to import a modified one like that for under $25k at least. consider the fact that the car has to basically be returned to stock to go through compliance so theres all the associated labour costs of removing and then re-installing the mods
plus $18k might just get you a stock series 2
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
    • @Murray_Calavera iam just considering options 🙂 of course it is very expensive so that why i ask here 🙂  @joshuaho96 I looked at that GCG hybrid(i remember looking at it few weeks before) So this is "that" hybrid where i send them my turbo and they upgrade the inside to Garrett stuff and then they send it back. It cost around 1200-1300 USD which is FAR cheaper than the HKS and it is what iam looking for(i just do not have experience like this...to send something off to "upgrade" ) @tylink720 that is like 150 USD turbo no? 😄 I dont think i have the "ease on my mind" with this kind of turbo. I just put over 7000k USD to "LINK" up my engine...dont want to blow it up with cheap turbo 😄     EDIT: https://www.cj-motor.com/gcg-turbo-charger-for-nissan-rb20det-rb25det-high?srsltid=AfmBOooVeOZ6CZ6r1AIv5m-KPaa6BvudIPJTY8LW78khkd-gQlsaCht9 I looked at this and it seems ok? It is that CGC hybrid and it costs around 1250 USD (with back shipping). Do any of you have experience with this hybrid on NEO turbo? I quickly look thru the forum/web and it seems very good.
