Remember my car was initially running dangerously lean a/f of around 13.7 and up with the stocko item, so now this new fuel pump has hopefully brought that down to 12ish a/f ratios by supplying the required amount of fuel, hence 'making' the power that shud have been there. yes its in low revs then fine, my sock has got a bit of play, i was thinking that maybe the pump doset have enough pressure in low revs cos of this - then on higher revs, it has built up the pressure??
Just putting a fuel pump doesnt increase the power in the car it just enables it to run more power just like a front mount,you will however make more power when you combine it with such mods as turbo injectors where you require more fuel to be pumped out so not sure what your talking about there.
The problem does sound strange as it is missing then working fine, would have thought it was surging from maybe mounting the pump to high but your saying it in low revs and then its fine.
Yes and no. If the afr was leaner than about 13.5 he would be losing power.
You really need to rewire the pump before the tune. U cant do it after or the tune will be out again.
Dude, 13.7 isn't that lean at all... Besides, a bigger fuel pump won't change anything, the stock regulator is keeping the fuel pressure the same, and the injectors are still opening the same amount, so your AFR won'tt change from a fuel pump swap. I reckon the pump isn't receiving the right voltage, the fuel pressure is dropping and the "misses" are lean spots, but it probably wont detonate at those low revs in that situation, it'll just miss instead...
when is it reading that AFR? under boost? on idle?
and how were you measuring it?
13.7 is lean on boost....
Yeah he didn't mention that, my bad.
Regardless, re-wire your fuel pump, and if it still happens, ask your tuner what's going on.
My x-trail does the same thing, I've tuned it myself, played with EVERYTHING possible to fix it, and have no idea what's going on. It just randomly goes lean and misses, if you apply the throttle @ 1700rpm, worse when cold, I think i've narrowed it down to intake turbulence. But yours sounds like a fuel pump voltage issue...
VERY interested to hear the outcome, good luck dude.
Get the car on a dyno and have someone check it out properly. For all you know you could have a dodgy afm or blocked fuel filter, it could be anything. It prob has nothing to do with the fuel pump at all.
It has to do with the fuel pump dude, before changing to the walbro, this issue wasnt there at ALL, I reckon re-wiring is the go - will get my tuner to do that - how much shud I be paying for that??
I know its simple - relay, and then wire from batt positive etc, grounding, but nobody has any pictures anywhere - I need to know things like how the modified wiring goes into the tank, at what point it is cut and where in the chasis it is grounded etc, as u know the battery in the R34 is in the bonnet not boot. I already got amplifier wiring running from battery + to boot with its own fuse (amp is out), can I use that??? Just connect the relay etc.. Does the relay need to sit in bonnet beside battery?
And I saw the a/f ratios after driving on 2nd to 7000rpms and it showed around 13.7 everywhere on the tuners laptop running nistune. Didnt get it tuned then, and yeah on idle it is around 15, normal driving on boost is high 12s to mostly mid 13s..
Post a pic of ur maf sensor in its current position.
Also what ecu are u running to control the fuel pump voltage for ur returnless fuel system. This is very important for ur setup and a fuel pressure gauge must be input to the ecu.
Yes u can rewire the fuel pump using the amp wiring. But get a relay with a fuse in it. Connect the amp power to the power in of the relay think its pin 30.
Then the current trigger of ur fuel pump ( is r34 neg trigger? Im not sure)if its neg trigger cut the negative going to the fuel pump and connect the ecu side of the cut to connect to pin ? (mental blank. Its the earth pin)
If its positive trigger cut the positive to thr fuel pump and connect the current power in from ecu side of the cut to pin?(mental blank, its the other power in NOT PIN 30)
then pin 87 power out goes to ur fuel pump positive the other half of the above cut wire.
Then negative of the fuel pump wire should be grounded to the chassis. U dont need to remove the fuel pump to do any of this. Use the stock wiring approx 300mm of it anyway.
I mount my relay on the right side of the boot well half way up the side.
Don't have a maf sensor, it has an EMS stinger 4424, uses map sensor for load source.
pump has a constant 12v supply, still running the standard fpr, i'm going to install a aeromotive regulator and reference it to boost, the more stable fuel pressure might fix the missing porblem @ 1700rpm... If I want to run more than 12psi, I need a better fpr anyway, and I think it's generally not up for the job at all.
the stinger has no fuel pressure compensation values, it's got air temp and water temperature compensation tables for timing and fuel, anti-lag, two step, 15 other customisable outputs.
And a fuel and ignition map "override", never learnt to use this.
Can you elaborate on why pump voltage is important in a returnless setup?
PM me if you don't wanna clutter this thread!
returnless systems sometimes rely on the ecu to control voltage to the pump depending on a feed back on what the fuel pressure is at the rail, but because yours has a fuel pressure regulator this might not be the case.
is your wiring to the fuel pump stock ie 12volt constant? did your factory setup have a sensor on the fuel rail?
Returnless setups are a good idea due to the facts that you dont get fuel splash when the fuel returns to the tank and the fuel will stay alot cooler as its not travelling through the hot fuel rail then returning to the tank constantly,
but as we all run a return type system it will work for your setup too.
ok now that i am half awake,
-Pin 30 is power in from your amp power wire
-Pin 87 is your power out ( this goes to the positive side of the fuel pump)
-Pin 86 can be connected to the earth trigger, or if its positive trigger connect 86 to the chassis
-Pin 85 can be connected to the positive trigger or if its negative trigger connect this to a switched ignition 12v source
-then connect the fuel pump earth to the chassis,
doing this will give the fuel pump full battery voltage, but still be controlled by the ecu incase of an accident where the engine stops the fuel pump will stop, and wont pump a tank load of fuel all around the car if the line is ruptured
Hey Jez, thanks very much man, you have been extremely helpful, now all those pins, where are they, are these the pins -30, 85, 86, 87 etc, on the plug going into the white fuel pump plastic cap that seals the tank?? Theres 2 plugs and 3 hoses there. So that means I dont have to open that plastic thingy and take out the fuel pump with bracket as it can be done from above, right? And how do I know which is the positive / negative trigger, and by 'switched ignition 12v source' - that is the battery, right?? Sorry for being such a noob, but in all my DIYs I find this the most confusing as theres no real pics I could find, just diagrams..
Theres so many relays in www.jaycar.com.au - this is the only one with a fuse: can I use this?
cartItem_02.gifcartItem_03.gifcartItem_04.gifcartItem_06.gifcartItem_07.gifCAT. NO. SY4076cartItem_09.gif RRP$8.95cartItem_11.gifcartItem_12.gifcartItem_13.gifcartItem_14.gifcartItem_15.gifcartItem_16.gifproduct_9879.jpg CLICK TO ENLARGE
Automotive Fused Relay - SPST 15A
Designed for automotive applications, these quality relays have an integrated blade fuse and metal mounting bracket. The contacts are rated for 15A, making them suitable for installations of aftermarket horns etc.
* 12V 15A contacts
* SPST
* Fuse included
QTY 1+$8.95 10+$7.95 25+$6.95 Enter Quantity spacer.gifspacer.gifcartItem_26.gifcartItem_27.gifcartItem_28.gif<< RETURN[ Top of Page ]
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
