I stopped going after they told me my helmet was too old :laugh:
good luck with getting your 10sec
haha they told me that last time too,
just went out n got myself a $99 that complied to all standards from that massive bike shop in auburn lol.
just went n did a few practice launches n i think i got it down pat now so hopefully ill get there
https://www.sau.com.au/forums/topic/360514-drags/#findComment-5756388
Thinking of going this wednesday. Be nice to grab a high 12 with my car...doubt it though. Will be my first time at the drags and have tire sympathy (considering i only put them on not long ago).. need to get an ebc with gain control too.
Be good to hear a gt-r running 10 heh! Might see ya there - i'll be in the silver 33 if i get my butt there.
https://www.sau.com.au/forums/topic/360514-drags/#findComment-5757384
oh wow just noticed you're in the gong, WSID is like 10 minutes from my house lol even then I can't be f'd heading out anymore because I work in the city & shittyrail drains the life out of me
I was gonna buy a cheapo helmet too, last time I went to the drags my car was stock standard & worn tyres I reckon I could shave a good .4/5 secs off my PB with my mods & decent tyres/launch
https://www.sau.com.au/forums/topic/360514-drags/#findComment-5760237
Yeh I was spewin' when I got the time card with that time.
I run a full croydon built 2.6 with t88-33d, light head porting for a safe 420kw @ all 4s. Also has full os giken 5 speed and nismo twin plate clutch
https://www.sau.com.au/forums/topic/360514-drags/#findComment-5762549
Yea was pretty damn close
How did ur twin plate hold up with the launches, were you just dumping the clutch on it at full RPM?
I only ask cause i got a nismo twin plate sittin on my engine atm, and im goin for 400rwkw and a 10sec pass
https://www.sau.com.au/forums/topic/360514-drags/#findComment-5762694
nah just going to stick with WSID.
will put a cage in it sum time at the end of this year just trying to decide if i get a full or half cage.
and then its just about deciding what mods to do to go faster
https://www.sau.com.au/forums/topic/360514-drags/#findComment-5764946
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
