11 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Dan - i *think* it's called the 3910 cefiro..
it's the red and white pair of cefiros from japan with the white rims
made a lot of noise on japcar blogs late last year...
i think the rims were were origin DNA???
can anybody please post pics? they all seem to be dead links... :( there's a red one and a white one :)
stock bodied iirc!
  • Replies 64
Cheers big ears
See stock is sexy...
Make a copy of the bumper.. Tweak the mouth a bit.. Maybe turn it upside down so it doesn't "smile"
And extend the front lip / replace it with a shakotan chin spoiler...
I'd do that. Just clean with no swoop
Not a fan of the stock bar/lip at all. I can see the advantages of it on a street car though, no uber flares or superlow cop-bait features.
Quick update: Company I'm talking to is chasing down the possibility of producing a symmetrical Autech S1 kit in plastic.
i want in on this gangbang.
I get the feeling I'm going to get shot if this falls through... so i'll throw it out there. NO PROMISES!!!
Personally I'm happy with a fibreglass kit if it's not going to cost a squillon dollars and there's a mold but I'll keep everybody posted on the progress.
My only problem with the stock bars is that they bend inwards too much / become to narrow.
Compare inside bottom of bumper to where the doors / body are on the chassis.
Should atleast be inline with that. Or where the park light / indicator is where it joins the fender, straight drop downwards, rather than merge back in.
By comparison, all aftermarket kits overfix this by going bullshit wide with the flaring (ie Uras)
IMO This is why Autech is sought after, it keeps the car "stock looking" somewhat as Rowan suggested, and also squares up the shape of the body a bit without going over the top. Subtle yet very effective.
Edited by Nic_A31
shot? no. banned? yes. :D no pressure.
lol I need plastic cos my stock front bar (no splitter) sits 2inches off the ground at the current height. Autech is lower so it'll sit nice and low. At that height fibreglass will shatter when I go over a lane marker/rock.
Instant gentleman would be sweet, but:
1) too much work to make a mould
2) doesn't really suit the square faces of the ceffy. Chaser etc are much more rounded.
Autech's the only one that goes straight down and doesn't look mad homo by flaring out. You can buy good quality fibreglass Autech kits from aeromaster.jp pretty cheap... but it's kinda pointless.
I'd like to see Autech series 1, "widened" mouth, symmetrical hole on the drivers side,
and something I've always wanted to see....... what about incorporating the factory side illumination lamps?
^^ this is a good idea , i wouldn't go too much wider with the 'mouth' probably 3-5cm each way?
Widened mouth? How big are the coolers you're running to need a widened mouth?
I'll ask about the add on lip next time we speak but i'm going with the symmetrical Autech bar for now as it's simple (which hopefully means cheap). Baby steps, IF that works out then I'll start looking at other stuff like the lip, roof spoiler and so on.
Edited by a31rb25
If this happens and I get one, I'm just gonna cut mine to put the lamps in... should be pretty straightforward.
Latest news: For legal reasons any design has to be different, so...... an Autech bar with a symmetrical intake would be enough. As would the TBO bar with a less pronounced full lip (doesn't recess at the mouth). Same goes with any other kit pieces.
Plastic molding is not a financially viable option - one place was happy happy to do it but wanted $25K up front to make the mold - metal molds, plastic injection. On top of that would be materials, labour, etc.
Still waiting to hear back about FRP. Fibreglass is looking like the best option at the moment.
Ideas on tweaks for these rear bars? (I've chosen these for ease of molding)
1)
2)
3)
Edited by a31rb25
I prefer the last Autech pic. With the "bubbles" around the number plate section.
I know, all you haters hate them on the front and rear bars, but stfu, I reckon it looks better with them,
As for tweaking them, I dunno...I'll let others decide.
+1 , Make the D part beside the number plate slightly shorter (or the number plate hole bigger to accomodate adm numberplates) and make the exhaust cut out wider . AAAaaand if you look at a stock rear bar , they have a groove just under the tail lights , you could add that in?
Combine both those Autech bars.
The S2 is flat at the bottom, the S1 (1st pic) isn't.
I dont like how the S1 flares on the sides as it heads back to the wheel arches though.
Keep it even along the sides, have that cut out in the middle rear, THAT, on a series 2 Autech.
If its even, it'll make the whole car look better when slammed. A bumper that is uneven in edge (ie S1 Autech, Uras, Dianna, etc) looks shitty. More "boxed" shape like S2 Autech. Does that even make sense?
As Toffy said, widder to accomodate Aus plates.
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
