Hey hows it going, i got a R33 GTS-T Series 2, i have a stock diff in this car and i would like to know if my revs are showing correctly on my spedo as when im doing 100ks an hour in my skyline it shows that im doing just under 3k in 5th gear is this correct as my SAFC doesnt show that it shows im doing roughly 2550-2600.
I aint sure who i should trust.
Yours Truly,
Nick
https://www.sau.com.au/forums/topic/360608-quick-question/
There are a heap of online calculators online which can tell you how much rpm you are doing at x speed. I'll see if I can calculate the rpm for 100km in 5th
According to this calculator in an R33 GTST with the standard 4.1 rear diff ratio, you would be doing just above 2500rpm at 100km/h. Your SAFC and dash read from the same signal, the digital is always better as it doesn't just go out of whack like the mechanical gauge would.
You shouldn't notice this just in 5th. All your gears and speeds are gonna be out. Get your cluster checked or replaced. Ive got a spare R33 GTST cluster with 118xxxkm on it. Works a treat and if you're in Sydney its yours for cheap.
Edited by SargeRX8
https://www.sau.com.au/forums/topic/360608-quick-question/#findComment-5758478
Is there anyway to refurbish a tachometer as i dont want to really change the k's its done.
yea it can be fixed, its just a matter of finding someone capable of doing it as its a fairly tricky little precision instrument. alternatively if you obtain another tacho you can always get the mileage changed on it. this would be done by the same person who would repair them. when your asking around about it, make it clear that your not trying to wind back an odometer illegitimately. you've just bought a replacement for your car and want it to reflect your car's true mileage.
i've been through the same thing before, i found a guy that ran a small business fixing precision electronics like these and he got really suspicious when i asked him if he could change the odometer on the new tacho i'd bought, took a little convincing that it was legit lol.
https://www.sau.com.au/forums/topic/360608-quick-question/#findComment-5760716
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
