Hey, I just have a concern with my S2 R33 GTS-t which I thought was normal at first but is now making me worried.
Whenever I start my car, I notice after a minute or two that water droplets form inside the exhaust. After around 30secs or so, there is white smoke/steam which is emitted from the exhaust, which I presume is the water droplets evaporating.
I know it's definitely water forming in there as when I run my finger around inside the tip, I can see it's clearly water.
This isn't limited to just cold morning start ups, but anytime during the day whenever I start the car.
I recently had a new Hypergear ATR43G3 fitted and is almost fully tuned (tuner ran out of time) but if it's any help, after the turbo was fitted the car was overheating but the system got bled so it runs ok now. They did use a fair bit of tap water though as they ended up spraying my coolant everywhere so I'll be getting a full cooling system flush soon.
Any ideas or am I being paranoid?
Cheers.
https://www.sau.com.au/forums/topic/360890-water-droplets-and-smoke/
Cheers.
A by-product of fuel combustion is water dude. Unless its spitting coloured droplets, your being paranoid.
Everyone's car does it - just some more noticeable than others due to exhaust temps.
Rest easy
James
Hey mate, thanks for the reply.
The water droplets only appeared in large quantities after I installed the new turbo and the droplets/steam appear whenever the car is started :(
Nah, it's clear so definelty water.
At first I thought it was a blown head gasket (if it is, then FML!!!), but under the radiator cap and under the oil filler cap I can't see any cross contamination or any milky substance so what could it be that's causing the all-the-sudden condensation?
Could it be the water lines to the turbo wernt done propery and it's going out the exhaust or something?
Edited by turbodragon
I think your problem is your looking to deep into things.
You installed a new turbo, and now your noticing all these different things.
It is completely normal for the water droplets to show up. The reason you notice it at startup is because the exhaust isnt hot enough yet.
Take a look around when your driving. You will now probly notice cars shooting water out the exhaust when they take off up a hill. It happens occasionally.
I know when i installed my new ECU and tuned it, i was paying so much attention to how the car felt, id decided that it was no better if not worse, than the stock ECU. Clearly it wasnt :P
Same here, sometimes water droplet forms on the exhaust on a cold day & when the car is running if I put my hand near the exhaust I can feel water vapor.
Same as the OP, that scared the shit out of me & being the pessimistic person I am, I immediately thought about a head gasket failure (or warped head) & started to look at the usual head gasket symptoms but couldn't found anything (other than my head telling me that my car 'seems' to be running crappier than usual) until one day I was driving my dad's Corolla & found that if I put my hand near its pea shooter sized exhaust I can feel also water vapor from the exhaust gas too...
:closed eyes:
Hahaha well I'm glad has similar experiences and I'm just freaking out over nothing :blush:
But what would you quantify as "few water droplets"?
Reason being my whole exhaust diameter has droplets (i.e there's droplets all the way around on the inside walls) :(
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
    • 300kW is so boring in a Skyline, you'll get spanked by someone's mum's Golf with Alibaba pipes, and an email tune.
