hi guys. as the topic says.
head sets, what do you use, or what could you recommend?
im torn between some nice stereo ones.....and spending tooo much on a set of surround ones.
mostly for FPS. prefferably all platform compatible. but specifically PC
what brands should be avoided?
cheers :)
*if ive missed an existing thread. noob me up and point me in the right direction plz :rolleyes:
https://www.sau.com.au/forums/topic/360914-gaming-headset/
  • Replies 42
cheers. ive heard nothing but good things about the sennheiser of any type.
but was a little unsure on the turtle beach gear. the HD280 is a bit more than i wanted to spend. and the p11 looks real nice :)
seems most people dont go the the surround headsets
https://www.sau.com.au/forums/topic/360914-gaming-headset/#findComment-5761911
Senheisers are awesome. They produce fantastic sound quality minus the large pricetag. As madaz said, they block out heaps of noise so you hear every enemy and each bullet shell as it hits the ground. Downside is they are pretty tight and after a while it feels as though your head will implode.
https://www.sau.com.au/forums/topic/360914-gaming-headset/#findComment-5761978
Senheisers HD550 for me. I've modified them to HD595 specs. It's a 10min job yet the price difference between 555 & 595 is like $60-$70
You need a amp'd sound card to drive them properly but by fuck they sound awesome.
I don't believe in the "5.1" headphones, load of shit i reckon.
The 595/555 certainly sound directional and with the Auzentech soundcard i have driving it all, very impressed. Great for watching movies & music which i listen to of a lot hence i grabbed these ones.
https://www.sau.com.au/forums/topic/360914-gaming-headset/#findComment-5762323
are you talking about the 280pro Elias as the 212pro are a lot better for everyday wearing
The 280s. If I knew they hurt the head after a while I would have gone another model bit after listening to the quality I decided to keep them. I love quality and am very picky when it comes to home entrainment/gaming.
https://www.sau.com.au/forums/topic/360914-gaming-headset/#findComment-5762408
used alot of plantronics over the years and they ALWAYS ended up breaking - even their 'decent' ones with external soundcards
i have 2 sets of razer megalodon at the moment - 1 spare for when the first set brakes - but for me compared to siberia's and plantronics the razer's are already well out infront.
this is for gaming only of course.
https://www.sau.com.au/forums/topic/360914-gaming-headset/#findComment-5764525
hahaha you went from plantronics to razer!?
at least plantronics specialise in headsets, razer gear full stop is generally crap and prone to breaking.
TBH the best headset I've owned was an Exsound Conch, but I can't find anyone who still sells them (only cost $20 too!)
https://www.sau.com.au/forums/topic/360914-gaming-headset/#findComment-5767804
so true man....a friend of mine has a razor keyboard too....looks cheap...aswell as having some issues. and overpriced.
i have heard of the plantronics breaking occasionally.....but for half the price of a turtle beach or Sein.....i can handle that for the few hrs of gameplay i do in a week
https://www.sau.com.au/forums/topic/360914-gaming-headset/#findComment-5769818
i've had the lyocsa keyboard for just on 3-3.5 years and cant fault it so far. apart from the rubber grips wearing on the WSAD. but then again. who needs to look at those letters anyway :thumbsup:
altho i would rather drink toilet water than go over to their headphones.
https://www.sau.com.au/forums/topic/360914-gaming-headset/#findComment-5769907
ugh I thought razer were the tits until I went through two lycosa keyboards, two copperhead mice and currently onto my 2nd deathadder mouse. Deathadder is the comfiest most responsive mouse i've ever used but apart from that will never buy razer again.
+1 to plantronics, had a pair of 777's that lasted me many hours of gaming through uni.
if you want cheap and effective though, go creative fatality - good sound and mic for around $40
https://www.sau.com.au/forums/topic/360914-gaming-headset/#findComment-5769989
I'm using a Logitech G35 and find it awesome for gaming.
and +1 on never buying a Razer again... sent back one mouse under warranty and the 2nd mouse becomes problematic(same problem as the first) shortly after the warranty period expires... it was a Razer Lachesis. Before that I used a Logitech mouse and never had a problem. Now I'm using a Microsoft Explorer 3.0
https://www.sau.com.au/forums/topic/360914-gaming-headset/#findComment-5770220
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
