I am starting this topic trying to find all the Toowoomba Skyline Owners on this site. So if your in Toowoomba post up in here so i know how many are out there and would like to try and organize a meet up as some point in the near future to get to know you all. So if you see a guy following you in a 32 I am not trying to stalk you I just want to have a chat with you.
Thanks all
Chris
  • Like 1
https://www.sau.com.au/forums/topic/361137-toowoomba-skyline-owners/
Also, as of our recent AGM and new executive team, we now have four major cruises per year instead of just the one Annual SCC
That being said, our next major cruise will be out towards toowoomba, so it would be a great opportunity for you guys and girls out there to come and get involved and meet some other members :thumbsup:
There is a 33 parked down the road from me, and I have seen at least 5 others getting around town.
Tbar must be forum handicapped apart from Chris and I?
Let me rep with an SAU sticker!!!! I have ugandan dollars!!!
Edited by sonnyQ
We are in the process of making business cars for the club to promote it,
Join the club and we will send you a pair of stickers AND some business cards so you can leave one under the wiper of this 33 with a note on the back :thumbsup:
can someone PM me cost and bank details for membership :)
assuming I fall under regional?
Cheers
http://www.sauqld.com/ipb/index.php?showtopic=1648
Bank details there and some pricing info. I would guess that you may be classified as regional.
i am also up here but i doubt any of you would have seen mine, its done 119km in the nearly 4 years ive owned it
if theres a local meet up i mayyyyyyyy consider putting more km on the car
chris, do you work for smithy?? i see your car often parked across the road, if i see it there can i have a look around it one day or would you rather i see you first??
i work down at parts for cars
Yeah I do work for smithy. Yeah someone told me that one of you's down at parts for cars had a
skyline. You don't own the black r32 v-spec by any chance? You are more then welcome to look at my car.
I am going to try and organize a meet up in the near future once I can get into contact with a few more owners. Also if you are keen the Brisbane/Ipswich and maybe even gold coast owners are coming up to toowoomba on the 15th of may for a meet and greet. Their should be some really nice cars there. Would be nice to get a good turn out for the toowoomba guys
I have. bring the thing out will ya!
yeah chris thats me black 32 gtr v spec 1
chris rogers.... na it will stay in the shed sound asleeeeeep.... at least there, i know it is safe
I want the plates off your's for my V-spec 1. Would it be possible to have a look at your car sometime?
I follow that quite well. same as mine once its done. need to ask you a question about yours as well re: rear wheel arches.
yeah we could probably work something out to have a look maybe
if you want the plates make me an offer i cant refuse, see how you go.....
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
