Interesting to see the longer duration and larger exhaust valves together, would complement each other.
88mm doesn't need to be totally sleeved. Just sonic tested. Have done a few, usually number 3 needs a sleeve only.
Matt
This is a Txt from my engine build on 2mm+ IN 3+Ex:
Yep it would fit in the chamber. Better if it was a 88mm bore( sleeved block) No point though as I can't remove that much material in the port or I'll find water
Actuators went from hks to 19 and now to 25psi units exhaust side must be getting close to the limits.
Quite excited to get it on e85 should be faster again with the extra torque from the fuel and push closer to 500kw if the turbos hold up..
Awesome!
Please keep us updated when you switch to E85 :)
Matt
Thats interesting we had problems with my first block i split number 2 bore went to install a sleeve and found it was only mm thick half way down the cylinder. After seeing that we decided to bin the block for a brand N1.
Awesome!
:thumbsup:
Track update: PB 10.66 134MPH 1.73 60ft
Axle tramp finally in check - next time out warm rear tires.
2 runs only one with a bad bog and the second bad wheel spin then got booted...
Ran on mickey thompson 275 17" drag radials
Pump/tolulene tune up around 600RWHP lowish boost (26psi)
Getting there slowly..
Sweet as!
Any videos of the PB?
Now you're booted, do you have to upgrade the safety gear and get it inspected or was it more just a general piss off mate style thing?
More like a 'nice run mate dont bother coming around for another pass tonight'!
Give it a few weeks and try again. :thumbsup:
Run from mid last year
    • Remember kids - if you can't afford to buy 2 GTRs......
    • I know people cry at the price of the Getrag 12-14k for a conversion now, but it really is a nice mid point. Not going to get change from 10k on a gearset installed.  $30k++ for sequential.   I know you run the risk of a damaged used one and parts are hard to get but as a street car gearbox its really hard to beat. If you enjoy a more traditional manual, its the choice no question.
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yep, its been down for a while, as I understand it it will be back soon.
