  • Replies 110
I didn't get to speak to him today, but hopefully i will tomorrow
so what style have you guys decided on: the silver or grey/aluminium style?
the supplier will apply double sided tape on each badge which is strategically placed for it not to be seen.
Hey man i prefer the shiny silver one. looks sweet. Buy the badges people. The more people want, the quicker i get my Badge . I live near ur place mate so i could drop by and give ya the deposit if u like. How strong is the tape. Cuz i fink it will be a target for badging?
yeh no worries....cum around and check the samples out if u want...but id prefer not to accept deposit until we get the numbers cuz it would be inconvenient for both of us
as for the tape, to say its really strong is an understatement
oh thats good then. Ill pop down when u get the numbers and give ya the deposit. Dont worry it looks very good in the picture so i know it looks better in the flesh (metal) :)
Damnit half the people on this forum own GTS-T'z and they cant pull 36 bucks out. Common Guyz
Guest INASNT
Use the 3M industrial tape, it sets like cement after a few minutes.
**** why would you wanna stick it down super strong???
The last thing u want is some little **** prying your badge off with a screw driver and wrecking your paint work because its so hard to get off...,
a $36 badge vs a respray of your boot.
update: (13)
ME x 1
INASNT x1
jaqule x 2
WazR32GTSt x1
skyline x2
ABuSD x1
Blade x1
krzysiu x1
eriktufa x1
lukits01 x1
knore x1
ok guys if i get 20 ppl im gonna order them and try to reduce the overall ordered quantity by 5
omg this has taken off soo quickly. its jumped in the mid teens in less than 2 dayz :rofl: 4 more to go guyz, common :rofl: Guess ill be popping down to ur place sooner DSKYLINE2C to place my deposit.
ok fair enuff
ill be accepting deposits as of today....use can either pay cash or in my account. if you choose to pay directly into my account please specify USERNAME and pm me...also pm me ur address if ur interstate. My phone number is 0403 556 037.
edited:
Bank: ANZ
BSB: 013 128
ACC: 517 820 036
cheers
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
