Unfinished Project Bits
After I win the lottos... So sounds like Samsonas, valve springs, a new bigger turbo, and maybe a super charger like all the school kids are dreaming of for twin charging, and you'll have the perfect daily driver. Oh, and maybe Bosch motorsport ABS for you too.
Hopefully that's not too confusing for the PoPo in Canada! Mr Plod even thinking you had Nitrous plumbed in on the street in Australia would lead to a 7-10 year stint in maximum security...
Yes, it will take a fair amount of solution but the sodium citrate + citric acid + detergent is cheap stuff. Use laundry detergent instead of dish soap if you want to reduce the bubbles, also you could just buy sodium citrate and add some citric acid to the mix until you get to a weakly acidic solution if you don't feel like dealing with all the bubbling generated by adding everything together. For a fuel tank you need quite a lot of distilled water but it's probably worth the effort. -
Actually looks like a Nitrous setup now 😆
