Back in 2001 I bought this wine red series 1 R33 gtst from an importer, It was an awesome car. I drove the ass off it and it just kept coming back for more and more. I started drifting it soon after buying it. That led to doing some sprints at QR and then on to Gatton and Leyburn. At just under 200,000 km the timing belt tensioner stud snapped. Re-building the engine was go, but what did I really want to do with this car down the track...... Race it harder! Cage went in and lots didn't.
It went well, real well. Things got modified more and more and looked less and less like a street car. After Noosa hill 2009 I decided it was time to pull it down and have a good look at how everything was going after 4/5 years of racing it. I also wanted to tidy up a lot of the suspension experiments, some worked extremely well. Like all best laid plans, I decided to essentialy re-shell it all into a road car I had lying around as a spare.... just in-case.
Some one should buy this thing, has been an awesome road car and exceeded all expectations on the track.
Noosa Hill June 2010, 1st in class & new class record
SCMA Super Sprint Series, outright champion 2010
Gatton 2011, 1st in class.(I broke my thumb 2 days before the event)
So Gentle, She's on the road back. I wanted to get the dumby motor in today. I had to work out how to get the RB30 mounts to fit the 33 cross member. My tig welding is getting better. there is a 6mm rubber cushion in there, other wise its a solid job. It is getting dry sumped so the angle isn't a major concern other than oil drainage.
old tyre rub marks
https://www.sau.com.au/forums/topic/361275-gentle-thats-her-name/
A question, why did you try so had to shove RB30 mounts in? I'm assuming RB26/30DETT is being built, but most people just mod the rb25 mounts to slot the motor down...
What're you expecting vibration to be like with out much rubber?
I had a set of 30 mounts laying about,I will have a look at it with some 25 mounts. Besides, I figured, 30 block, 30 mounts.
They are the turbs I will be starting out with.
Things have taken a left turn as well. I have had to re-shell everything back into this shell. The Black 1 had a bit of a moment :whistling::mellow::wacko::spank::down:
Right, so a tree hit here
that exploded the wing and bent the rail near the front of the wheel, squashed the floor, tore the bumper rio out and bent the opposite side of the car.
This side didn't touch a thing.
So all the driveline has been transferd over in as simple way posible....eg
and in about 12 hours...we were done!
well, its ready to race but not how it was ment to be.
It is where it was at the end of 09, freshend up somewat.
Until the 30/26, superbox, revised suspension and Carbon/Kavlar/FRP components are in, it is not yet done.
Edited by Noddy
Oh yeh, there is a hell of a kink in the passengers sill, in the middle of the passenger door.... I think this is fixable, with time and a serious rack session.
hahah it is always the navigator's side
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
