Back in 2001 I bought this wine red series 1 R33 gtst from an importer, It was an awesome car. I drove the ass off it and it just kept coming back for more and more. I started drifting it soon after buying it. That led to doing some sprints at QR and then on to Gatton and Leyburn. At just under 200,000 km the timing belt tensioner stud snapped. Re-building the engine was go, but what did I really want to do with this car down the track...... Race it harder! Cage went in and lots didn't.
It went well, real well. Things got modified more and more and looked less and less like a street car. After Noosa hill 2009 I decided it was time to pull it down and have a good look at how everything was going after 4/5 years of racing it. I also wanted to tidy up a lot of the suspension experiments, some worked extremely well. Like all best laid plans, I decided to essentialy re-shell it all into a road car I had lying around as a spare.... just in-case.
Some one should buy this thing, has been an awesome road car and exceeded all expectations on the track.
Noosa Hill June 2010, 1st in class & new class record
SCMA Super Sprint Series, outright champion 2010
Gatton 2011, 1st in class.(I broke my thumb 2 days before the event)
So Gentle, She's on the road back. I wanted to get the dumby motor in today. I had to work out how to get the RB30 mounts to fit the 33 cross member. My tig welding is getting better. there is a 6mm rubber cushion in there, other wise its a solid job. It is getting dry sumped so the angle isn't a major concern other than oil drainage.
old tyre rub marks
https://www.sau.com.au/forums/topic/361275-gentle-thats-her-name/
A question, why did you try so had to shove RB30 mounts in? I'm assuming RB26/30DETT is being built, but most people just mod the rb25 mounts to slot the motor down...
What're you expecting vibration to be like with out much rubber?
I had a set of 30 mounts laying about,I will have a look at it with some 25 mounts. Besides, I figured, 30 block, 30 mounts.
They are the turbs I will be starting out with.
Things have taken a left turn as well. I have had to re-shell everything back into this shell. The Black 1 had a bit of a moment :whistling::mellow::wacko::spank::down:
Right, so a tree hit here
that exploded the wing and bent the rail near the front of the wheel, squashed the floor, tore the bumper rio out and bent the opposite side of the car.
This side didn't touch a thing.
So all the driveline has been transferd over in as simple way posible....eg
and in about 12 hours...we were done!
well, its ready to race but not how it was ment to be.
It is where it was at the end of 09, freshend up somewat.
Until the 30/26, superbox, revised suspension and Carbon/Kavlar/FRP components are in, it is not yet done.
Edited by Noddy
Oh yeh, there is a hell of a kink in the passengers sill, in the middle of the passenger door.... I think this is fixable, with time and a serious rack session.
hahah it is always the navigator's side
    • The title should have posted "EFR7670 exhaust housing selection RB26" I can seem to edit thr title on my Android.
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
