Tuesday 26 April at 930? there is also a 640 session but 930 works better if we are going to have dinner before hand, I have to work the next day but I think it will be worth being tired over
All those attending add their name to the below list:
Attendees:
nerm (+1 Maybe)
https://www.sau.com.au/forums/topic/361343-fast-5/page/2/#findComment-5768795
  • Replies 58
I thought Lemon Grass (as mentioned in your first post Nerm) was in Tuggers
Either way I'm not too fussed on where food is consumed. What's Trilogy though?
Im pretty sure there is a Lemon Grass in Woden.. also in Civic too i believe.
Trilogy replaced Babars and the food is essentially the same
https://www.sau.com.au/forums/topic/361343-fast-5/page/2/#findComment-5772683
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
