I'm back from overseas and I'm cleaning out the shed to fund my TD06 requirments.
Precision Turbo- Billet comp wheel, PT5557 570hp turbo. Less than 1500km old, some dyno runs and a couple of gymkhana events. This turbo is currently on my rb25/R32 (some may have seen the set up in action at the DEC gymkhana event last year). The car is currntly making 250rwkw with more in it. Dyno sheet and or ride can be arranged.
Turbo- $1000
Wastegate- $350
Stock manifold wastegate adapter- $250
Package- $1400
Nismo 260km/h dash for R32 GTR- 87k kms on the clock. As far as I know it suits early 32's. $250
Generic JJR oil cooler kit- Used condition, but everything is there. $200
Twin td05 kit to suit rb26. Used condition. Manifolds are very well made (japanese) with no cracks. Turbos are in ok condition, minimal shaft play and thrust play. Comes with dump pipes. $1000
Genuine N1 oil pump- new in box. $350
Turbosmart FPR-800 fuel pressure regulator- used but in good condition, includes some fittings. $200
Turbosmart bleed valve- used. cheap. $50
Turbosmart V port blow off valve- used. also cheap. $75
VH45/Q45 V8 90mm throttle body- used but good condition. has no tps but your rb20/25 s1 will bolt straight on. also has coolant temp idle adjustment (cool!). $250
RB Flywheel- used, no cracks. $100
SPEC clutch plate- used. $50
HKS GT 2835- needs a rebuild and the housings are good. $350
RB26 conrods- straight and undamaged. $120
HKS cast low mount exhaust manifold- is don is good, but has a crack along the divider inside... I have had a quote for repair (correctly) for $150 by a cast material welding specialist. Rare item $450
HKS square base wastegate- has bolts, valve seat and gasket. $350
Trust rb26 pod adapters- good condition, needs polishing. $100
Intercooler- generic JJR. $100
Package deals can be made, all shipping will be additional (don't ask for shipping prices unless your very keen) and all parts can be inspected/picked up from south Tasmania- Hobart Area.
PM me here or call/sms
Cheers
Justin
Cooler sold to me :cheers:
If you are interested in selling that intake pipe in your first Rb25 picture, let me know. Or tell me, is it custom made or bought? If so how much and where from? Maybe you can PM me a pic of your intake system(infront of the turbo)?
Edited by SargeRX8
Sorry the intake pipe isn't for sale... it's just a 90 deg cast trust pipe and a 90 deg alloy bend... there's no provision for bov return or breather intake.
Cheers
Justin
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
