Just bumping this...
What can I expect as to the SAU turn out on Monday 12th April in Fremantle? Is anyone still up for meeting up?
Official time, how many people etc?
  • Replies 79
and I will be there. Will try and drag the girlfriend along too, but I don't hold out much hope :P
Cheers
Rob
Yeah is that day a pubic holiday?
It's the easter long weekend right?
Anyway, how about we meet errrr, somewhere in Fremantle (I have no idea where a good place to meet is), at 5pm?
depends what they want to do ...... somewhere like little creatures has atmosphere but isnt so loud that you cant talk .... not sure what time open til on friday night ... then always can go clubbing afterwards.
