11 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Are you able to get cheaper prices on Skyline bars if they are bought with the group buy?
I'll pm you some prices later, they are better than retail, but not as good as group buy, due to the individual nature.
Cheers, Dale
No worries mate
Specifically after a 24mm (extra heavy-duty) adjustable rear for R32.
3 point adjustment if possible...
Cheers
PM sent :thumbsup:
hey guys,
Im interested, but was wondering if this group buy goes through, since you all only need 1 more, when would we take delivery?
thanks
It would be roughly 2 weeks from reciept of the last payment. So, if I allow 2 weeks for everyone to transfer funds; four weeks.
Of course the faster the payments are made; the quicker I can make the order.
It would appear we have enough interest, I'll contact my supplier tomorrow, and get solid prices. Then I'll make it official.
Edited by Daleo
How much for 350z?
Bars are the same for V35's and 350Z, so as per the first post;
On the Stagea; we had had prices going from; Front 32mm adjustable, RRP; $320 GB; $235!. Rear 20mm adjustable; RRP; $285 GB; $210! A huge saving!
The V35 bars are basically the same prices, so I should be able to offer the same kind of prices!
Cheers, Dale.
if they can be delivered before queens brithday weekend, i'll be interested
thanks
When you look at it the queens birthday is the 13th of June. From today thats 6 weeks. Including yourself we will have the numbers. Lets factor in 1 week for organizing of funds then 2- 3 weeks shipment, even add 1 week in for contingency, you are looking at maximum 5 weeks for the bars to show up at your door.
It all just depends how fast everyone can get the moola to Daleo
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
