hey guys iv'e been rebuilding a rb25 from the ground up, i put the bottom end back up, with CP forged pistons and rb26 conrods (which my brother got :unsure: ) i had it all spinning, THEN i put the head on, tightened it down (stupid thing to do) then spinning the crank, and it seems its locked in place??? doesnt turn clockwise/anti-clockwise??? its STUCK ?! i double checked that the valves wern't hitting pistons, they wern't. So i only have 2 other feasible options. either;
1. Iv'e tightened the con-rod bolts to tight, but this cant be because iv'e spun the engine before hand.
2. The head hasn't been machined to fit the new 87mm CP pistons, which is causing a sort of lip between the block and the head, so the piston cannot move.
Does anyone have any helpful ideas, i need a solution urgently, as this is for my year 12 automotive HSC and i need the engine complete ASAP! :(
https://www.sau.com.au/forums/topic/362563-rb25det-not-turning-over/
yes cams are in the motor, i made sure valves aren't touching by checking which pistons are at the top, and then checked where the lobes are on the cams to make sure none of the valves were pushed down, i have CYL 1 at BTDC and the cams at 15 degree mark where they are mean't to be, and their is no timing belt
If there is no cam belt, then the cams won't turn with the crank, and you will end up with valves still protruding into piston space.
What does "CYL 1 at BTDC" mean? Do you mean TDC? (B = Before)
How does the RB26 rod compare in length to RB25 rods? Maybe the RB26 rods are too long, and are trying to push the piston crown into the combustion chamber.
thanks for that info mad082, really appreciate, im thinking of taking the head off instead of the cams, as its alot easier, BTDC, it just before top dead centre, where i its mean't to sit, or its top dead centre. im still learning mechanics, so bear with me please! :) the engine has no movement Clockwise OR Anti-Clockwise, like the pistons are superglued to the cylinder wall lol...
yes, but if you just take out the cams you can confirm it is pistons touching valves which is the most likely. Just undo the cam bolts slowly, start at the middle and undo a turn or 2 at a time on each bolt.
also, are the spark plugs in? if so when you try and turn the balancer it is producing compression which can make it harder than you expect to turn the motor. But either way I would not turn it far before putting the timing belt on.
You mentioned #1 is at TDC which is correct. The pin in the cams should point at the marking on the backing plate, or about 280o on lnlet and 70o on exhaust.
But if it was the valves hitting, i would atleast be able to move it the other way, like clockwise would make piston go up a little more and hit valve, but if i go anti-clockwise, it would just go back down not going near the valves, and no their is no sparkplugs. thanks alot for the info :)
not really. you have pistons going up and pistons going down at the same time. so the valves may be hitting 2 pistons stopping you from turning it either way.
but regardless, you shouldn't be trying to spin the engine without the cams turning as well otherwise you run the risk of damaging both pistons and valves
hey again, got some new updates; i took the head off today and it wasnt the problem, the engine is still locked in place, so me and the teacher tomorow are going to turn the engine over and have a look at the bottom end to see anything wrong,if their is nothing wrong their we are going to take off the oil pump, is it possible for the oil pump to cease up?
i would appreciate any information you would give,thanks
yeah i took apart the oil pump,the bolts were TIGHT AS :down: it fell apart in the 3 pieces but it's stuffed, it doesnt turn at all, so im going to buy a brand new oil pump or good 2nd hand one. It was the same one as i took off when i was rebuilding it...oh well, atleast we found the problem,and it was nothing serious like pistons hitting valves etc.
    • Pressure when IDLING, is meant to be 51PSi... So that amperage value needs to go up a fair chunk... I'd personally be factoring for more like 12amp at least on those runs, and at that point you need to hope the already there wiring doesn't drop you a volt or two, as that's a lot of fuel pressure flow drop off from 13.5 to 12V! Taking idle pressure of 51psi, means the pump will be drawing a MINIMUM of 9amps all the time based on your reading of the graph (3bar base, then allowing an extra 0.5bar for boost = roughly 51psi)
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
