(this may not belong here so please move to appropriate forum if necessary)
I bought the car about 2 months ago now, and recently got my first rego renewal papers to see that the cars registered as an RB20 4 cylinder???
-How does this happen is it the previous owner or the D.O.T.'s doing?
-What do I do about this? Is it just as simple as going into a listening centre and telling them someone firetrucked up?
also I'm in WA if that affects the circumstance at all.
https://www.sau.com.au/forums/topic/362631-r32-gts-t-registered-as-a-4-cyl/
I might be wrong but I'd just leave it as long as you insure it for what is is and not go off the rego papers you should be fine
I wouldnt go through a blueslip or wa equivalent unless needed
My car is listed at the wrong weight on the rego papers and I've been told not to bother trying to correct it as it will end up costing me more than it's worth in savings if te weights bought down
Heaps of imports are regoed as sedans when they are clearly coupes and moat of the time people just leave it
Edited by stig mick
yeah, why?
Clearly the guy at the rta who put through the compliance papers never saw the car in real life
I had an S13 that said sedan, they don't even make an S13 sedan, and the back seats were only good for children under 5
So in other words, just leave it as is, would that affect the third party insurance included with the rego? Obviously I've got private insurance as well. But if I was to crash would I be screwed?
It wouldn't have any effect of 3rd party cause you were not the person who entered the details when you complied the car
Plus I'm sure the price for 3rd party injury would be the same whether it was 4 or 6 cylinders
Edited by stig mick
Alot of people belive it or not know nothing about cars they aren't interested in them so if they had an error on the registration papers how would they know so its not up to you to pick it up
I'm normally an honest person and would point this kinda stuff out, but if it's saving me money and because it's completely there fault I can't be held liable for any paperwork mistakes on their behalf it'll stay how it is.
I thought about telling them, but in the end thought "nah, its saving me about $15 per rego compared to my mum's V6 Camry, LOL", so the cheap arse Asian inside me isn't complaining... :yes:
The times I got pulled over & the cops ran checks through their data base on my car & they didn't mention anything about the 4 cyl issue neither (probably didn't know...).
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
