Hi Guys and Gals,
Need to sell my car that iv bearley driven..
Its a 1989 Nissan r32 Sedan gts-t Manual in White
Gtr Steering Wheel, Gtr N1 Headlights, Gtr Genuine Alloy Bonnet, Gtr Genuine Grill, Gtr Front Bar and all been freshly painted by DT Panels.
100,000km Service Kit, Heavy Duty Excedy Clutch, Lightened Flywheel, Turbo Smart Plumb back BOV, JJR Front Strut Brace, Trust gear knob, Apexi Coilovers, 3inch Exhaust and few more extras that iv proberly missed..
Comes with stock suspension to pass RWC, The engine has 90,000kms.
Cars pretty stock and almost ready for RWC, Car does NOT come with RWC or REG as i have no time and no funds.
Asking price $6000ono
Car can be viewed in the Ringwood area, pics will be up shortly..
Thanks.
Edited by sami`
https://www.sau.com.au/forums/topic/363522-r32-4-door-gts-t-manual/
  • 5 weeks later...
  • 1 month later...
  • 1 month later...
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
