I have R32 front strut tops in the garage i think. 99% confident they are the same, I know the front shocks or coil overs are interchangeable between 32 and 33 for the only difference between the two cars is 33 rears are longer. Let me know if you want me to track them down?
that would be good mate! how much would you be after?
I need money sale!
-chrome 17" work "vs" wheels
-Rb25 alternator, Igniter, coil pack harness, Air flow meter starting at $50
-rb20/25 cross over pipe from
Cefiro, factory BOV delete $50
-Rb26 r33 Front diff/sump, twin turbo pipe, ac, power steer pump
-s13 5 stud rear conversion with near new slotted s14 rotors $200
-front rotors r32 gtr, r32 Gtst, r33 Gtst, s14, slotted and not, various
-pair 4 stud alloy skidders 16 or 15x7 with tyres no pictures $50
-pile of 14" pintara/skyline steelies with tyres
-new coilovers instock s14, s13, r31 etc $750 pair or 1300 a set
-upgrade tie rods and ends s13/14/15 and r31 kits starting at 150 per kit
-skyline and silvia dual rear caliper brackets and full kits, one for r32/33/34 rear end, one for r31, starting at $350
-turbo s13 sway bars, make your factory non turbo shell handle properly (huge difference) $50 each
-ae86 project 5000-8000 depend on spec
-rb25 motor package $2000
-rb25 clutch package
-silvia/skyline kaaz 2 way diff $800
-s13 welded diffs starting at $100 exchange
-silvia driveshafts from $50 each
-s13 tail lights, factory and factory tinted $50 a pair
-180sx and s14 clear bumper indicators $40 a pair
-180sx factory tail lights
-ca18 parts and ca20det stroker kit
-4age clutch kits new and used
-4age quad throttle kits
-4age billet cam/crank/water/alternator pulleys
-4age trd head gasket $100
-ecus for ca18 and sr20
-sr20 crank- perfect
-sr20 block- perfect factory size bores
-sets of sr20 rods
-sr20 tomei 87mm forged pistons used but perfect condition $200
-sr20 used perfect condition 9.5:1 pistons
-sr20 s14/15 vipec ecu $1200
-sr20 injectors 370s, 444s and 550s instock $50 $200 $350
-available as a kit or seperate sr20 parts above
-turbosmart fpr800 fuel reg with fittings $150
-rb26 forged pistons new,custom, $1200+
-rb26 crank, long drive fitted, storage surface rust suit clean and polish $400
-rb26 rods factory and forged
-rb26 n1 block needs sleeve in one cylinder
-sr20 gti-r turbo suit rebuild (or use for .86 rear housing)
-gtr/rb20/25/sr20 turbo actuators
-s13 knuckles $150
-s13, 14, 15 and r32 33 and r31 front lower arms instock
-s13/4/5 factory rear arms and one s13 subframe instock
-sr, ca, rb factory radiators instock starting at $40, aftermarket also instock starting $200
-thermofans, new ba falcon, modied for sr20 bolt on, $150
-clutch fans and hubs, factory and aftermarket for all skyline and silvia instock
-rb20, s13, s14 power steering pumps instock starting $80
-rb20 and rb25 r32 engine mounts
-s13 manual gearstick surround unbroken $25
-slip on and bolt on wheel spacers 4 stud
-cam and timing covers rb20, rb26, rb25, ca18 and sr20 s13 in stock
-misc used but good pod filters $10 no pics
-180sx drivers front guard $100
-180sx type x bumper with reo and foam no lights slight damage $300 (less than half the going rate)
Rb26 below
R34 n1 rb26 block. Needs sleeve in one cylinder, onced sleeved will be stronger than factory. $500 Rb26 crank from r32, fitted with collar. Needs a clean and polish from storage. $400
Custom made pistons to take factory rings, je. Various compression ratio. Nothing less than 1200 a set cost double to make
New genuine rings also instock for extra
Set of rb26 rods with arp2000 bolts
Think I have a set of jun rb26 rods can't remember If sold or not
Rb26 r34 n1 nismo adjustable cam gears $150
Rb26 cams, factory and new tomei type b
Rb26 new air flow meters
Rb26 nismo gmax twin plate clutch no friction discs
Rb26 harmonic balancers r32 r33 Nd r34
Power steer pumps r32 33 34
Gearbox rebuild parts 33 and 34
Upgrade nismo input shaft r34
27 spline rarer than 24 from memory
Rb26 cam covers
Nismo thermostats
N1 water pump I think I have one left
Tomei head gasket kits
Nitto headgasket kits I think I have one left
Factory r33 exhaust manifolds
R34 n1 fabricated at nismo dump pipes
Rb26 custom fabbed dumps also
Stock injectors also
Gearboxes
4 sr20
1 rb20
1 rb30
1 r32 gtr need synchro on 3/4
Heaps more stuff, need money for 370z drift car
Hey boys and girls I'm chasing the little part where the oil pressure sender screws into on a 26 as the thread in mine is nearly cactus and Nissan dont make them anymore.
Part looks like this
And goes onto this.
Yeah I tapped it with a 1/8th bit but the thread is only about half there. Any ideas on where to get the reducer fittings from? I also want one to go in my trust/greddy oil cooler sandwhich plate but havent had any luck finding anything so far.
If your using a r32 radiator a r32 item is the go. I don't believe that a r33 radiator fits properly. And as far as 25 in a 32 most stuff like the fan line up the same.
And I have a r32 shroud if you want it.
ร—
ร—
