Hi everyone. Friday night, Pre-Drift Nats cruise.
Near the corner of Bouke St and Harbour Esp.Mini Map
This is the intersection, just...Follow the Yellow Road
Car Park looks like this
Time: 7pm - 10pm
Adam and the guys from Fulllock Motorsport want a big meet for all interstate people, and D1 drivers from Japan etc etc.
So get out the wax, wash the cars and come along for a big meet-up and LOTS of pics etc.
Come along and say hi to everyone, meet the people that have put the Drift Nats on for all you guys.
No idiotic behaviour... burnouts etc will no be tolerated.
Remember, you are there to represent your respective forums/clubs in the eyes of interstate and international visitors, and the general public too.
There will be police presence at the meet, not sure how long, or at what stage
They wont be there to defect anyone or anything sinister like has happened to other 'clubs' (not naming names there)
So dont be too worried about them, if your being good, they are going to do the same and not hassle us directly.
Afterwards, if people want to cruise, then that can be decided on the night.
This is just a big meet is a MASSIVE area to get a number of the 'better' car clubs of Melb together to show how big, and how much quality the Vic Imports scene has.
Apologies for the late notice, but we still expect at least 50+ cars
So dont be someone who misses out on this.
Hope to see you there.
Ash, SAU-Vic Events Co-ordinator
In conjunction with Adam and the Fulllock Motorsport Team
https://www.sau.com.au/forums/topic/36386-fri-19th-pre-drift-nats-meet-up/
Dont wanna get everyone too excited.
HPI - 'might' come along. i am in contact with one of the guys from there.
So we'll see if they want to come down or not.
I'll get back to everyone when i know.
So if your only 'thinking' about coming, stop, and come along just in case :)
btw i assume we are allowed to bring friends who dont have skylines?
cause my mate has a 180 and his bro has a 'rolla with a 4AGZE worked engine (his first car on his Ps lol) want to come along too.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
