Hi i was wondering if anyone here knows of, or has seen an automatic GTR?
as i have recently sustained a spinal cord injury and as a result i am unable to drive Manual :-(
I was looking at buying a R34 GTR before my accident but now im questioning weather it is still worth it?
if any one could help me with this, i would be greatly apreciated
https://www.sau.com.au/forums/topic/363914-automatic-gtr/
where are you located. if your REALLY want to spend the cash and money, alot of Auto Trans joints should be able to do a conversion strong enough to handle..
I know my Trans joint mechanic has built his 33GTR to have a clutch with an automatic shifting box. its pretty frickin sweet. He is able to launch the car, and change gears as quick as the shift kit will allow
RVO Automatics is Dandenong Victoria!
https://www.sau.com.au/forums/topic/363914-automatic-gtr/#findComment-5806913
Yes it can be done and has many times.
And plenty strong enough.
http://www.fullboost.com.au/forum/showthread.php?t=8317
I got a quote of about $5500 for a modified RE4R03A. But there are a few TH400 and powerglides being built
https://www.sau.com.au/forums/topic/363914-automatic-gtr/#findComment-5806983
Hi mate,
Sorry to hear of your injuries. However, although not many, there are indeed some pluses of having an automatic GTR.
A mate of mine built his stock GTS4 into a GTR, spent a lot of money his automatic GTR runs through gears really quick and shifts fast...tough too...it's a good mix of luxury and sports.
Let me know how you go.
Cheers.
https://www.sau.com.au/forums/topic/363914-automatic-gtr/#findComment-5807170
  • 2 months later...
Maybe an auto from an R34 GTt or C34 Stagea Turbo might be the go. It has tiptronic mode too. But you will need a non-turbo TCU to control the shifting.
Best of my knowledge automatic turbo skylines/stagea have their TCU+ECU in one unit, where as the non-turbo models have the ECU and TCU as separate units.
Failing that you may need to go for a fully aftermarket ECU/TCU combo.
I think there was a guy on these forums by the name SATANIC, he had an RB26/30 coupled to an auto, might be worth a look as a start.
https://www.sau.com.au/forums/topic/363914-automatic-gtr/#findComment-5931542
    • I'm going to slap an old nismo logo sticker on my spare one and sell it to the land of the free for a thousand bucks
    • lol, probably should have read further!
    • Well - they have arrived.  And they are easy on the eye to put it mildly... These only have three bolts - but for a start there is a key that fits with vacuum like precision..  And as you can see by my ruler, the interface is large..   I listened to a podcast on HP Academy about Dan (KiwiCNC) and I'm more than comfortable he knows what he is doing. R35 Bearing assembly should arrive later today so can mock that up for a look. Can't wait to get these on and get some brake pressure logging too. IMG_3860.MP4
    • I would be very confident that they are the same parts (the 2 different SKUs). It seems very clear that you can drop the cam in the 2-way opening, or in the other opening. If you arrange it in the other opening in the same way that you see any other 1-way diff, ie, with the flat of the cam up against the 1° side of the opening, then it would work as a 1-way. It can only spread the ramps when driving forwards - cannot spread the ramps on overrun. It would then appear obvious that if you put the cam into the opening "backwards", that you would get the angled flats of the cam working onto the "points" of the 1° side of the opening, which would give you ramp spread in both loading directions. I do wonder if the forward direction of the 1.5-way config is equivalent to the forward direction of the 2-way, seeing as the cams are flipped and the angled surfaces on those would need to be the same on each side - AND - clearly when installed in either the 2-way or 1-1ay configuration they are not intended to work exactly the same (the ramp angles on the 2-way are 10° different between forward and backward, and the ramp doesn't exist in the 1-way config). 'twere me, I think I would rather actually have a set of rings that offered the 2-way with two different sets of ramp angles, say the 55/45 of the existing design and maybe a 45/37.5 combo for a less aggressive effect), AND another set of rings with a dedicated 1.5-way opening and a dedicated 1-way opening. The 1.5-way opening would actually have the steeper angle on the overdrive side that causes it to be less pushy than the forward drive angle, like you see in many other diffs. But really - if this Nismo thing is thought out properly and all those surfaces work on each other the way that they need to, who am I to argue?
