  • Replies 69
hi have a 33 ive had for awhile
things have changed so need to get rid of it
rb25det series 2 coil packs - $100
Heya bud,
Looking for coilpacks for S2 33GTST - What condition are these in? any cracks in them? Was it playing up under full load over 4000 - 4500?
Thanks
Mike.
