Guys
As a lot of you will look in on this thread between now and DECA.
Just a reminder we are still looking for people to help run the day.
So if your heading up for a look or bringing friends there help would
be fantastic..
Cheers Wayne.
  • Replies 221
Posted Images
Don't want to be an arse, but will you guys/girls be doing any form of CAMS licencing Saturday morning? I think you used to, just not sure if you still do. If so what price so I can bring exact monies. If not, is it $50.00 for the AASA? Sorry I left this so late, but there is always one... And it's usally me.
Thanks in advance,
Brendan.
P.S. Bring on Saturday, rain, hail, or shine... it'll be warm in the pub!
Thanks in advance,
Brendan.
$50 for the AASA on the is a little more work but can do it on the day
Thanks in advance,
Brendan.
As Leon said, can do AASA on day (We'll only talk about you afterwards :P) - just please bring correct cash as we wont have change :)
So excited.... The maps look great and easy to remember. :D
However the S14 is still in the Workshop so I have stolen an Evo 6 for the weekend.
Move me and Sean into 4WD Category, I will bring new entry forms up with me.
Does that mean a display afterwards of 4WD Heli's? :woot:
Another successful/awesome DECA
Lots of fun was had, water was splashed, tires were smoked...
Big thanks to the sponsors, organizers and volunteers and anyone else that made this DECA happen
Good to see some old faces as well as meet some new people
Great day! Thanks to all organisers and volunteers. It rained in the morning and turned the skidpan into a pool, but mostly dried up by arvo so everyone was happy at some part of the day :D
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
