hey
i am having an issue with the new motor in my r33.
its a series 2 and the car over fuels big time at idle.
i changed the injectors out of the old motor and put them into the new motor and its miss firing but not over fueling any more.
the injectors removed are grey coloured (too much fuel) and the ones that went in are purple tops??
dose any one know what these purple tops are??
cheers James
https://www.sau.com.au/forums/topic/364348-rb25-injector-help/
yeah im taking the plugs out tonight to clean them.
the purple tops were in the first motor that went bang. i sold the old head of it and number 4 piston had very bad divits on the top of it.
im assuming due to detionation, but the engine was stock standard.
im assuming that number 4 injector must have been dropping in and out for a while and that is was caused the engine to go bang.
the missus who drives the car said it would just start miss firing and carrying on and then every time i was driving it it was fine.
getting back to the injectors are these purple tops hard to come by??
  • 1 year later...
Uh I wanted to check which injectors I had on my skyline and I guess now they are the standard purples. What I tried to do was take off the two top screws to find a part number and f**k me I almost completely stripped the screw trying to get it out. Any trick to getting them out? Engine was warm when I tried so I let it cool to the metal was not expanded but still no luck. WD40 help?
maybe the just need a good test and clean, pitty i binned my old ones.
Edited by AngryRBGTX
Puts me into modified class though :/
try some boiling water over it and hit the top of the screw driver with a hammer
you might have to grind the head off and drill it out, who would know it was not factory anyway? just paint it black , you'd have to know rbs to know if it werent stock.
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
    • 8.5 +37 = should fit rear, but I think it'll hit on front. What you want is low 30s/high 20's front, mid 30's rear. That 17" screenshot you posted looks good, I'd run it on my R32 (but that's long dead now). For tyre sizes, my rule of thumb is: 8': 235, 9": 255. But that's just my opinion. Nismo sizes: 18x8.5+35/18x9.5+38 is a good starting point.
