All good, just thought i'd give it a try to help some people who either can't get it to work (and believe me, it took some time) or just get frustrated at it :)
I guess it's a bit cathartic somehow?
Also: Damn, coming as one piece sucks. I got mine third party from England somewhere with the nismo logo on it... hella fake, but they're ok.
  • Replies 86
The reason you can't find the hand brake boot part number is because it comes as part of the centre consol
Hi CPD,
Is this true does the hand brake boot come as part of the complete console assembly?
If this is the case I might be better off trying to find an aftermarket one (I think they exist), if not then maybe I could try secondf hand. If this is true NISSAN you suck!
Thanks Paul
I got mine outta the UK as well, just in plain black, the fit wasnt the greatest....but then again nothing fit on my 33 properly lol
Hi CPD,
Thanks Paul
To be honest I'm not sure; I can't read all the Japanese on the part listing :P But if that's so, that kinda sucks. Might just be worth the while to get a good aftermarket one.
No FASTing tonight guys; at my parent's house with MBP and it's not loaded on here.
If you want to know what model CD's you have in your pack, in one of the menu's you can click on "models on CD" (I think there is a CD icon next to the accident recommendation button).
It should show all the models. I've kept my FAST pretty up to date, and it does all skylines, some silvia's, left hand-drive models.... lots of other nissans too.
This is across:
a1
a2
a3
b1
b2
el1
el2
er
gl
gr
I think there is a thread that has been running for years somewhere on SAU with a whole bunch of people who were willing to look things up for others using FAST. You might want to post your offering in there too? =-]
Yeah, I saw the "VINS you want FASTed" thread, and I just don't know what all the colour codes are :) I pop in there every now and then to see if there's unanswered VINs, and to help out a bit :)
Pretty sure I've got most of those discs... Will check tomorrow night when I get back to my PC though. I'll post up on here about what I've got, or maybe get a mod to change my first post if possible.
I can't remember... I might have it zipped up somewhere; worst case, I'll get all the details and test if it'll work if I just zip up the folder it's in and get whatever Compatibility mode. If that works, I'll get it to you on a DVD before texi, and write some instructions as to how the hell to make it work (took me ages to work out how to get at those illustrations)
Hey Owen just one thing to watch out. The 5 digit number of the diagram is not the part number, it is only a part code. You need to double click it to add it to the main list. Then when you return to the main list, hit the "lookup parts" icon (or F9 from memory), and it will return the correct complete part number based on the VIN you enter.
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
