Hi Guys
Haven't been here for a while, how are you guys?
Anyways, i thought i might share with you guys my second attempt at installing a car pc. Even though the first time installed ok, i kinda think i was just pushing it a bit by force mounting the lcd on the dash pocket. This time i got a double din LED and took out the head unit. Looks a lot more cleaner and i can view it under direct sunlight! I'm still using the eeepc setup and still saving up for a proper pc with dc to dc psu. At the moment i'm using a Metra double din kit, which IMO is a little tacky and the buttons are a pain to press. But that's all i could afford back then.
Major improvements over the old setup include : OBD gauges, Bluetooth, Soundblaster X-FI (made a whole lot of difference to the audio quality) direct wiring instead of cigarette lighter plug :yucky:, and the latest version of Centrafuse (3.5)
Some technical specs for those of you interested:
- Lilliput EBY701 + ByByte double din frame
- eeepc 901 , 2gb ram, 64GB kingspec ssd
- SB X-Fi Pro USB Soundard
- Blazt II OBD Scanner / reader
- Sirf III GPS dongle
Btw, my old JVC AVX-910 is now for sale. For anyone interested PM me, Price : $400 Ono. This baby can play most files no worries and have an excellent audio quality. Originally bought 2 years ago for $750.
Pics at the bottom
OLD SETUP
NEW SETUP
JVC DECK FOR SALE
Comments, suggestion ,critics are welcome ! :cheers:
Edited by dodes47
https://www.sau.com.au/forums/topic/364518-carputer-install-v-20/
I'm still using the eeepc setup and still saving up for a proper pc with dc to dc psu....
Major improvements over the old setup include : OBD gauges, ....- Blazt II OBD Scanner / reader
Hi, I have basically finished my PC (built and Installed software) and its ready to plug into and mount in my car this weekend; finally!.
One of the peripherals is the Blazt cable. My PC will be mounted in the boot, with USB cables running into the cabin connecting things like my OBD. My concern is that the USB cable run may be a bit long for the Blazt cable. Even though USB2 is defined as having a 5m maximum length, I think the blatzt cable is said have a recommendation of being no greater than 2m from the USB port; It comes with a 2m cable.
My question, how long is your distance between the Blazt cable and the PC? and have you had any problems with this length?
Hey
I pretty much have the same setup. I ran 3 5M USB extension lead from the boot to the glovebox at the front. The blazt is connected to one of the port.
No problems whatsoever. It's just as responsive as when you hook it up straight to a laptop :)
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
