Hey all,
wanting to get into drifting and am after an r32 det or an s13 det. would be cool if it had coil overs and what not already done
cheers
what do you guys reckon of this rig ????
http://www.skylinesaustralia.com/forums/topic/362237-r32-rb25det-track-only-5000/
Edited by bk558462
https://www.sau.com.au/forums/topic/364763-wtb-r32-gtst-or-s13-det-drift-car/
hey man iv got a r32 in melb were r u
bout 2 hours away from melb. lookin into it but dont really wana spend to much, just kinda want a presentable car with a good motor !!
whats yours got done to it ???
How about a drift ready 180sx??
Sr20det, full bolt in rollcage, coilovers, black needs some tidying up been sitting around for years.
Located in Sydney though.
yeah thatd do the trick :D
send us a link :) im just after something cheapish
<5 grand and thats being generous haha. i want to try make a budget slier. or buy someone elses whos done with drifting n just wants to get rid of the car. would really love an s13 sr20det manual tho or an s13 with an rb
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
