  • Replies 67
Hey man, either the Vios or Zeta with graduation is my preference, I'm not sure what the difference is between them. It's street registered so the Maxis is over the top, I'm not sure on FRP/CF/Kevlar yet, depends on weight differences.
What were you thinking?
Edit: Just found this- vios is supposed to sit you a little lower. It does this by being recessed a little more on the bottom and having a slightly more curved back. I find this seating position more comfortable, especially for a street driven car. The vios also has smaller shoulder bolsters and the thigh supports are lower, making it a more livable seat for day to day. I have sat in a zeta too and it is also very comfortable. It is probably the seat i would choose for a more dedicated track car.
Probably go for the Vios because head clearance is a concern for me.
Edited by neil_se
I cant tell the difference between the Vios and Zeta seats tbh. They look virtually the same apart from slightly wider shoulder supports. But im not fussed, Vios sounds good in graduation. Mine is also for my street car.
So was it clear if there is rails supplied or definitely not?
Ah so they do come with something. Cool. Ill probably just fabricate my own rails to suit anyway.
Do you have height issues atm in your silvia? I dont remember you being overly tall back in the days of the s13 club with Jason, chris and the guys. Lol or maybe you are and its just my memory is shot.
I will be home tomorrow I can weigh the sample seats. I do not think there will any weight difference between the F/g, carbon or kevlar, as the are all wet laid . The carbon or kevlar or just for show.
Payment needs to be cash as I have to transfer payment to o/sea supplier in China. Could do paypal, so could use payal if you pay the fees.
Seats will need to use genuine Bride railings to suit the model seat you pick. The Gias and the Cuga for example have different mounting bolts centre.
The seatings come with basic sliding rails, so unless you can make your own mounting brackets to suit they will be no use.
SAAS I think make some rails to suit so you can use the supplied rails. I will see if I can find out some more info.
If someone onlys wants a single seat, still register your interest, as I might buy the matching pair.
I've been looking at photos, and 34 gtr bucket seats don't mess with the standard seat belts. Will these ones really be an issue?
The seat belt buckle mounts on the rail, not to the side of the seat, so they will work fine. No need to use a racing harness.
I can get copy Bride or Takara 4 or 5 point racing harness's if any wants.
have you actually used a std seatbelt with a full bucket? not exactly the best combination tbh...
the seatbelt doesnt hug the body (unless your quite huge), the seatbelt just goes from one edge of the seat to the other so you not held in by the seatbelt around the waist...
and yep the buckle is mounted on the rail but using a bucket its not exactly easy to get too, its quite a way down the side unless you make up some sort of extender plate so it sits higher...
Will the belt wear away at the side of the seat if a standard belt is used? I'd love a seat like this, but with the ability to keep the back ones.
OK, looks like I'll be on the lookout for a pair when I get my car :D
Are you wanting and talking about full buckets or recliners?
Recliners will be fine with standard selt belts, but you will have issues with full buckets and standard seat belts.
Kawasaki man is referring to r34gtr seats, so recliners not full buckets, hence my reply.
I think we are all getting confussed with what he wants.
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
