So here I am daydreaming again, this time about the upcoming (?) new rotary engine from Mazda, the 16X.
Summary:
2 x 800cc rotors
Direct injection
Increased compression
More fuel efficient
(probably less revs)
Here's my dreams/guestimations/predictions....
MX5 with 16X (NA), Torque 270Nm. Power 187kw @7300rpm
RX8 with same engine and hybrid drive. (http://www.roadandtrack.com/future-cars/2014-mazda-rx-8)
RX7 with 16X single turbo (mild boost 8psi). Torque 370Nm. Power 235kw @6800rpm. Weight 1260kg (2 seater only with rear luggage bench).
Here's hoping they build something like these.
With light weight and direct injection the rotary could be quite decent on fuel.
https://www.sau.com.au/forums/topic/364936-mazda-16x-rotary/
I just hope they keep the rotary engine available. Its always nice know that some manufacturers are still making sports cars.
Take note toyota, honda & mitsubishi (if you sre still going to kill off the evo).
Edited by gtr fan
Mazda has doubled the number of engineers on the rotary in the last 12 months. So it appears to be something that IS happening. The completely fresh design, direct injection and longer stroke should make it use a LOT less fuel....as long as they only go into light cars.
Although the RX8 was comparatively light it was still too heavy for the 13B. The 16X should have about 30% more torque.
Please please put it in an MX5, then turbo and put into a 2-seater RX7.
Why bother putting it into a mx5? They already have nice little engines that turbo/supercharge up plenty as it is. Easier to do that than to do an engine conversion.
No I'm saying Mazda should do it. Would be very easy for them. Apparently Mazda UK has put in an expression of interest to Mazda HQ for said car.
And a turbo/supercharged 4-cyl isn't really that comparable to a NA rotary.
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
