hey guys,
i need some help, my brakes lights arnt working but my rear park lights are, so it cant be a fuse. I recently pulled my dash out and fitted white dash so there is a good chance i knocked something on the way, i dont know what im looking for...
im thinking it must me something to do with the brake pedal switch thingo...
can someone please point me in the right direction??
thanks guys
It can be a fuse - the brake lights and tail / park lights are on two separate circuits.
Unlikely that all four would go at the same time, but you've checked that the globes are still OK?
There is possibly a fuse in the block under the steering wheel (don't know 33s that well).
The globes are "twin filament" type - one filament is the tail / park, and the other is the brake. It's possible for one filament to blow and not affect the workings of the other filament.
The fact that your hi-level brake doesn't work as well suggests a fuse. Or the switch on the brake pedal has been disconnected / broken.
with the 33's is there a "sensor" at the peddle, at the back of the stop peddle there my be a thing that when you stop, pressing the peddle depresses this button which sents the signal to the lights to get them to work, it may be the problem, if its there adjust it ?? then again if the 33's don't have this thing then its something else!!
It's a simple on-off switch. When the brake pedal is "up", there should be 12V on one side of the switch. When the pedal is "down", there should be 12V on BOTH sides.
Bingo.. :( thats the thing that stopped my stoplights from working all i did was adjust it and they worked fine, hope this is the case for the 33's??
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
