it's been proven before that you don't need the plenum changed unless you are flowing enough air for over 450hp.. also as mentioned before, it is a bastard of a job to do yourself and very expensive to make someone else do it for you (unless you know people in the trade who feel that they need a huge headache)
LOL GTST!
Your making it out like its rebuilding a motor! Its about 2 hours of welding & 2 hours of precision cutting & filling.
Its not that hard to do, provided you can weld aluminium. Lining it all up is the hardest part.
WLD747, ask around at Jap wreckers. youl pick one up cheap enough. Remember you dont need any of the bullshit stuff, (THorttles, linkages. etc) just the plenum.
Cheers guys,
Trev
I don't think GTST (Tolga from memory) is having a go at you.
Rather he's saying that any forward facing plenum on an RB25 is a lot of work installing because you have to eff around with FMIC pipes, injectors, rails etc. etc.
If you have the motor out, well fine but for a in car install, all the shite on the right side has to come out and some cutting of the metal under the washer bottle.
People do it for looks often and fair enough.
T.
Hi
I have a GTR plenum on my r32...
I bought the car with it on, my mates dad did the job, and i bought the car off him.
going by what he has told me...
BITCH! of a job, took him about 2 months to do, this was obviously not consistant more a weekend thing and he did it all himslef. it is not running 6 throttle bodies.
In my opinion the benifit is great, the car has got heaps of top end power but due to the short runners it loses power down low. The original idea was to twin turbo the rb20 but he ran out of time/money and didn't go ahead with it.
I have owned the car for a bout a year now and haven't had a problem, the only thng is I need more boost to take full benifi of the plenum..
PM me if you want to see some pics of the engine bay.
thanks Tony.
That is what I was getting at.
the picture above is with the engine out of the car so I guess it would be easier.
I also wanted to make a point that on an RB20 or RB25, you would have to have changed a WHOLE host of other parts, and be making HUGE power before the standard plenums become the restriction.
there is nothing wrong with the stock plenum, just it becomes more of a cosmetic change rather than performance. But reducing i/c piping helps!.
So why not run fmic pipes back under the coola past the air filter to the stock plenum?ceramic coat & heat wrap the pipes in the engine bay?wouldnt this be a good enough setup so you get less heat soak due to less piping in the bay as well??/ (i know there are shorter runs to a GTR plenum but theres money to be saved here for other mods especially when you dont know if the change is for looks or performance)but as far as iv heard the stock plenum is reliable for 450hp.Is this true?Tell us whats the power your chasing.Is it for a future engine upgrade?surely a setup like this would run cool enough for those figures.And while ur at it why not get a vented bonnet to keep those temps under controll.... :flamer:
Many coolers do run back underneath and not over the top.
ARC and Apex do this.
Heat soak is not really all that important with FMIC as the gas velocity does not allow much heat to transfer.
Oh and I do have both an ARC cooler and vented bonnet :rofl:
I think again HPI and Ben Ellis set the standard with 292rwkW with the standard plenum and he's not the only one.
T.
My car has the stock plenum modified to face forwards instead of going over the motor, al-la gtr plenum, but sits at the stock hight and doesn't get in the way of anything.
I'm not entirely sure if it flows better or is better but it looks good and makes fmic piping a hell of alot easier, it will look even better with a good polish. Hope that helps, but i dont have a scanner to get pics... oh well :rofl:
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
