Hi guys,
I'm removing my gts4 gearbox to be replaced with a 32 gtr gearbox due to upgrades, however the four bolts at the end of the input shaft seem to be a pain in the ass to get off...
Is there any tips on getting these out, they just seem overly tight and we havent managed to get them to move.
Cheers
Dan
https://www.sau.com.au/forums/topic/365290-removing-33-gts-4-gearbox/
Hi guys,
Cheers
Dan
Four bolts at the end of the input shaft?
Input shaft goes into your clutch and spigot bush......
Front driveshaft. Squirt with CRC or similar and leave for as long as possible. Try to get a ring spanner on and whack with hammer (from memory you need two spanners to stop the bolt turning with the nut). Presume you have already removed clutch slave cylinder?
Do you know how to use a 2nd spanner on the first to get more leverage? I've had to do it this way to get my drive shafts out before.
Need 2 x Ring/Open end spanners. Put the ring end on the bolt then put the ring end of the other spanner over the open end of the first spanner so that you can use it to turn the first spanner.
If this makes sense
Will help alot if the bolt is tight and you only have spanners to get it off
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
