Ad's Posted May 23, 2011 Share Posted May 23, 2011 (edited) Hey guys need some advice. I have installed and wired a S2 RB25DET into my HR31 and after sorting out a couple electrical dramas i now have another one. Long story short the car was running sweet and going good i parked up at the pub done the usual cool down car turned off fine, got back into it afterwards she started fine then the Mrs got in and said she seen a spark from the ecu kick panel. Parked up at hers went to turn the car off and just kept on running, gauges, turbo timer everything will go out except for the warning lights only way to turn it off is to stall it. I thought it was the turbo timer playing up so i disconnected it but still the same. Mate came around checked relays, computer, wiring fuses still nothing. I checked the ignition switch behind the barrel tonight no dice, even tapped it like another mate said to try. Same mate said to check the wiring if there is a poor connection or a short to a ground in the loom. (Will check this soon) Is there anything else that it could be or i may need to look at? I used this wiring diagram here: http://wiki.r31skylineclub.com/index.php?title=Wiring_an_RB25DET_into_an_R31 Mine was a little different as that is wrote up for a aussie 31. Cheers Adam Edited May 23, 2011 by Ad's Link to comment https://www.sau.com.au/forums/topic/365322-rb25det-wont-shut-down/ Share on other sites More sharing options...
Ad's Posted May 24, 2011 Author Share Posted May 24, 2011 Anyone? Link to comment https://www.sau.com.au/forums/topic/365322-rb25det-wont-shut-down/#findComment-5830770 Share on other sites More sharing options...
DVS JEZ Posted May 24, 2011 Share Posted May 24, 2011 Recheck the wiring for any shorts. Its weird that it didnt do it before so it shouldnt be the way u wired it. Check all fuses and relays. A relay might be staying energised. Link to comment https://www.sau.com.au/forums/topic/365322-rb25det-wont-shut-down/#findComment-5831379 Share on other sites More sharing options...
Ad's Posted May 25, 2011 Author Share Posted May 25, 2011 How will i know if a relay has stayed energised? Cheers Link to comment https://www.sau.com.au/forums/topic/365322-rb25det-wont-shut-down/#findComment-5832560 Share on other sites More sharing options...
Cassbo Posted May 25, 2011 Share Posted May 25, 2011 With a multimeter. Check the voltage on the coil side Link to comment https://www.sau.com.au/forums/topic/365322-rb25det-wont-shut-down/#findComment-5832659 Share on other sites More sharing options...
GTSBoy Posted June 11, 2011 Share Posted June 11, 2011 The turbo timer introduces another relay into the ignition wiring. Could be that one. Also, they don't have to stay energised to stay on. The contacts can weld together so that it's always on. If the turbo timer relay was the culprit, then finding a way to stall it out might reset the turbo timer so it looks like everything is off, but as soon as you start it back up, you have a switch providing power all the time that keeps the engine up even when you try to kill it. Link to comment https://www.sau.com.au/forums/topic/365322-rb25det-wont-shut-down/#findComment-5861229 Share on other sites More sharing options...
3BEPKA Posted June 11, 2011 Share Posted June 11, 2011 Had the same problem and it was turbo timer playing up. I had to remove it completely. Link to comment https://www.sau.com.au/forums/topic/365322-rb25det-wont-shut-down/#findComment-5861238 Share on other sites More sharing options...
StealthX Posted June 11, 2011 Share Posted June 11, 2011 Also had the same problem with greedy turbo timer, heat shrink had fallen off and a connection had grounded... Good luck bro! Link to comment https://www.sau.com.au/forums/topic/365322-rb25det-wont-shut-down/#findComment-5861257 Share on other sites More sharing options...
Ad's Posted June 14, 2011 Author Share Posted June 14, 2011 Not too sure but i just plugged in my power fc and the car turns on and off with out any trubbles now! Just the fuel pump keeps on priming though. One thing after another haha! Link to comment https://www.sau.com.au/forums/topic/365322-rb25det-wont-shut-down/#findComment-5865324 Share on other sites More sharing options...
