  • Replies 3.6k
Posted Images
so its rwkw but fw-torque :unsure:
did i mention i dont like mainline hahahah thats the weirdest shit tho
the bloke who took out the day bosko(ba f6) reeled off 510rwkw on a d/d then 447rwkw today with a very same torque figure 1088nm i think it was but that would definately be doing high nm @wheels running 24+psi through a 4litre i was totally shocked at the torque figure of mine in relation to kw but what bosko made 447/1088 seemen on the money........got me all a little confusious :mellow:
Last year i put my BF XR6T on the rollers at Willalls and reeled off 270rwkw compared to 327rwkw on Bruce's dyno (16psi, Process west surge tank, E-bay cooler, 40lb injectors, BP ultimate). TBH i wasnt too fussed with the difference i was actually expecting it. Next stage is bigger injectors, .7 front cover, E85 and decent clutch, will be tuning on 20-24psi. Be interesting to see the difference E85 makes....The Skyline was like night and day when it was tuned on E85, hoping for the same from the XR6.
Hey Sled the FG looks the goods mate.
Lee
when you need a clutch get a quote and get in touch with me ;)
Will do thanks Steve. Was thinking about getting an Extreme which is what i have in th Skyline (Very happy with it). What can you get your hands on???
Lee
Thanks Lee..........again we see a difference of almost 60rwkw between a Mainline and a DD (Disney Dyno) :P
I would've thought a difference of 10 - 20 rwkw would be the expected norm, but 60 - 80rwkw is just crazy and worth investigating as to why the huge difference......................MARTIN, WHERE ARE YOU!!!!
But it's a Ford Stevey Boy :P
Don't listen to the plebs Jet......you're more than welcome here bud............they're only jealous cause neither of them have ever experienced an 11 sec car (let alone a potential 10 sec job) :spank:
I've experienced a 10 second bike! Actually, I still ride it frequently ... does that count? :P Built a turboed 9 second bike, but that scared the shit outta me, so I guess I'm still not quite a 'man' yet :laugh:
Fords I can put up with. But if we start venturing into Commonwhore discussions, oh there'll be hell to pay :down:
are you sure that you guys aren't quoting tractive effort instead of true torque. XR6T's are making around the mid 500 Flywheel Nm mark from factory and you aren't doubling the power so there is no way that you are doubling the torque, since the two are related. So either your are making the power a lot later in the rev range or you aren't making 1000nm.
Edited by D_Stirls
I'd also like to say a big thank you to Matt Sherlock, Nightcrawler, Matty T, and Vu for coming over today to move some f**kin big H beams for my floor ... and drinking my beer and eating pizza!
Happy to help Roo! Let me know when the phase of the project is taking place and I'll bring some rigging gear over.
On the subject of thankyou's, Andrew and Matty T cheers boys for the carbon wrap job. Awesome effort :thumbsup:
Was a pleasure meeting you guys today.
No worries Matty, hope you like it! Nice to meet you too mate - happy to help out one of the SAU community. :D
mate you addicted to that stuff, looking for and suggesting what we can wrap on my car the other week.
hopefully catch up for a drink once your back from Kadina
assuming thats flywheel torque, thats still pretty decent (550-600nm at the wheels?). nice power
-D
There is a lot of confusion regarding torque readings on dynos.
The chassis dyno shows - Engine Torque At The Wheels. In other words engine torque MULTIPLIED by the gear ratio used, diff ratio, and tyre size. We can take that into account and correct it by using the Mainlines Derived Torque function which requires we take an engine speed reading during the run. This is something we normally do not do at dyno days as it takes a little longer to implement and 'hook up'.
yeh original were off heinrichs 510-421 and yeh both running e85 as u said if u can reel off a 300 on a mainline its guna cut the mustard nicely.we have done some back to back runs across adelaide hpt vs k.p.m vs southern hi tek but they were all d/d and were showing very ball park figures but the mainline seems to be the differ
There is no dyno debate, there are actually very simple explanations for the power difference.
When run in Shootout Mode (6F is recommened for the Falcon) the Dyno Dynamics - ADDS - power to the rear wheel reading to compensate for what it considers to be acceptable driveline loss. In othere words there is a bit of software in the dyno program that says 'Ok this is a forced induction six cylinder so it must have a gearbox that takes this much energy to turn, wheels this big, and a driveline that weighs this much....so lets multiply the rear wheel power by a correction factory as we put it on the screen' to give a nice figure
Mainline actually shows you the power - and torque - you ARE HITTING THE ROAD WITH
The rear wheel kilowatt figure is what you have accelerating you down the strip
The rear wheel torque figure (which is multiplied by the gear/diff ratio) is also what is accelerating you down the strip, hence you accelerate faster in third gear than fourth gear (more torque multiplication)
There is no manipulation of the figures to present them in a more readable or acceptable format. Raw data is the Mainlines strength
All the dynos that you state read close to each other are all applying the some artificial power reading correction to the figures, hence the warm fuzzy feel good factor for the laminate racers and the equally head scratching track times. Hope that makes sense :)
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
