You just know your in for an interesting day when your wife wakes you up early saying my waters broke.
Time to test the stag out.
Goodluck to the both of you...or should I say the 3 of you, hopefully it goes/went alright.
  • Replies 3.6k
Posted Images
Mate, tell her to take a teaspoon of cement and get her to catch a bus!! :P
Seriously though, hope everything goes well......and quick for her sake.
This should be a very good year for all of you Brad with everything else that's happening........all the best bud. :cheers:
So, what do people recommend as a decent pad for the rear?
Must be decent as they will cop a beating with the hydro hand brake
Looked into qfm, and no dice.
They don't have R33 GTS rears :-/
Might have to check out sprints and bend over for them :-(
I have a set of R33 GTST QFM A1RM rear pads if you are interested Craig
Goodluck with the whole process mate. All the best to everyone hope everything goes smoothly
my boss tries that technique making co-worker's push other workers to keep their area tidy and pull their weight for the bonus system
it doesn't work
but people who speed, drink drive and don't wear seat belts are ........ like the video says
Edited by Whiplash
Anyone in SA want my work Meisters happy to work out a price for SA members. looking to get my new wheels in a week or 2
http://www.skylinesaustralia.com/forums/topic/368210-18-work-meisters/
http://www.skylinesa...r35-gtrs-perth/
Seems no-one is safe anymore- thought I'd share this link -keep an eye open for anything turning up in sa.
This sounds like someone knew exactly what they were doing etc
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
