What a joke that video was, you're right Craig, as bad as SA for sure!
In other news, Transformers 3, oh.... my.... gawd....
Great movie!
are you actually saying that in a "fat pizza" accent?
def must add that to the to do list if thats the case
  • Replies 3.6k
Posted Images
so by your definition Simon, doing the opposite (ie run a muck on the roads and put all sorts of shit on Youtube) wouldn't make any difference then
We all need to be wary of what ammo we give Sapol & the Media.......to say it won't make any difference is not realistic unfortunately
no i never said that posting stupid shit wouldnt make a differance. dont get me wrong i think what they did is silly and they shouldnt have filmed it. but at the same time the punishment does NOT fit the crime.
open your eyes.. theres far bigger issues in the real world and in SA... crime rate is going up thro the roof. more home invasions then ever. more gun and knife violence and they are worried about 6 ppl doing 40kph over the limit (not even proven other then time lapse mind you) on a straight road late at night. this shit made the 1st segment of the 6o'clock news ffs. its being paraded and its bullshit. no one should be supporting that. not even SAU
Great movie!
that's why i love my mx-5 =) the only car i can get away with having half a cage :thumbsup:
I'm sorry but the punishment DOES fit the crime.
We are all the one paying for the D*CKS on the road through the CTP scheme, accident involving speed / racing are higher than ever. The more people that are injured and killed the more YOU and everyone else on here will have to pay for registration on your cars.
I don't care if you agree or disagree, but I have to deal with the people who are injured on a daily basis. So I'm all for making an example and hopefully people will think twice about doing the same and causing an injury or death.
The latest ABS figures I could find, which was the 09/10 Year Book Australia (http://www.abs.gov.au/AUSSTATS/[email protected]/Lookup/D18CA4EA930FF0D2CA25773700169CE5) has the latest figures comprising a comparison of 07 to 08 - and the number of accidents and fatalities dropped. Has it increased since? I couldn't find more 'recent' figures.
hahaha.......I have to deal with people who pretend to be injured on a daily basis :rofl2:
AND AS DISCUSSED AND POINTED OUT MANY TIMES ABOVE WE ARE NO LONGER TALKING ABOUT THE SUBJECT AS IT CAN ONLY GIVE THE MEDIA MORE AMMO WITH WHICH TO BEAT US UP.
Sheesh.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
