  • Replies 3.6k
Posted Images
anyone feel like mc donalds
quad core ;)
and my mate attempting to eat IT
I had to make one for a customer a few weeks back now....the biggest I have had to make so far is a cheese burger with 18 pieces of meat and cheese...was huge.
That double double pounder is bush league @ $10. I often get 2 McDoubles and put all the patties in one bun - great value for $4. Obviously for $10 you could get 5 x McDoubles (10 patties) and eat it - would be a ton more meat than a pound :)
im getting sick just thinking about that
hmm so for $10 i could have a 4 patty burger and have change to buy a Heffe Bier
Actually you are wrong there. The meat is in a ratio to 1 pound.
Cheese burgers, Mc Doubles (Double Beef N' Cheese), Double Beef and Bacon, Hamburger, and Big Macs use 10/1 or 10 patties to 1 pound
Quarter Pounders use 4/1 or 4 patties to 1 pound
Angus use 3/1 or 3 patties to 1 pound
So having 10 cheese burger patties is the same as 4 quarter pounder patties, ie 1 pound.
The number of stolen imports this week is really alarming to me. Im sure I speak for alot of people when I say the authorities need to step up their efforts to catch these people. We are relying on word of mouth to stay updated on the stolen cars, and if these people are caught by the police, we take one more step towards eliminating this problem.
Although if the people are caught by the people whose property they have blatantly stolen and abused, the repercussions would be alot worse than grand theft auto charges.
If the authorities are reading this post, please take this seriously and do something about it. It seems there is an organized regime of the same people targeting imports and driving the cars around to go steal other ones. Something like a bait could be simple enough to catch these people.
The reckless manner that these cars would be getting driven in should be enough of a sign to police to act on the matter.
I have personally run out into the middle of the street at 1am in my jocks brandishing a pool cue and half a mongrel when I thought my missus' camry was being stolen.
Does anyone know / use a courier they can recommend to get an engine delivered to Adelaide?
I can pickup at any depot this end, but would be nice if the courier could go get it and maybe stick it on a pallet that end to save me some hassle.
Any recommendations would be great. Need it from Vic to Adel if that helps
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
