  • Replies 3.6k
Posted Images
I run a high flow metal cat in mine, seems to do the job nicely.
That said with the old decat in it did pop some big flames,
And that's what the kids seem to want these days.
I've mad a couple for the lads at work for their cars when they go to the track. Personally I'd just have a full track exhaust and a street exhaust if track days were my thing!
I don't fancy the 5 figure EPA fine for not running one.
I have a cat + 2 f**koff big mufflers and it still pops flames.
Myth in SA. Never heard of anyone getting a fine for it in SA.
I run straight through a gutted cat and twin 4" blast pipes on an SR.
Annoying and loud.
Yep definitely a myth.
That said I'll happily make them for anyone, I won't fit them for people, that's their responsibility and their head on the chopping block.
My car pops flames with the metal cat for sure, but they were alot bigger with the old decat fitted.
Plus it does make a bit of difference to the note/sound of your car, the 2 lads at work with s14s def sound alot more tractor spec with the decat fitted.
Kind of a myth. You will only get the $10k fine if your a business.
The fine for an individual is only around the $500 mark; but since cats can die after 25,000 km's if your running overly rich and definitely will be on it's last legs after 80,000 they have a tough time proving that you knocked it out yourself. Decat though is hard to argue but you just say "what's a cat" and then claim it was on there when you bought the car. End of the day unless your caught with a crow bar in the cat your not getting fined.
Dave if your popping flames through your cat it's only a matter of time before you melt it, and then it'll either block up or break up and shoot out the back.
Edited by D_Stirls
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
