Bosch EV14 1000cc ID1000 style
These are a 3/4 length injector, 14mm Oring, top feed, high impedance, UScar style plug.
Tuff Car Parts can sort you out for those Adrian
steve i want anything 1000cc that will fit under my plazmaman!! LOL
status said those side feed are highflows
  • Replies 3.6k
Posted Images
i want to convert to top feed as they are cheaper/bigger cc/easier to find.
if i can find some genuine 1000cc drop in side feeds ill get them.
its either top feeds dont fit or side feeds are hiflows or not avail!
FML
Wow the Aussie dollar is in freefall after the USA debt bailout announcement - $1.10.7 2 days ago, has just bottomed out at $1.07.0 - better buy up any parts you want from overseas now kids!
Eyebrow height is the one point, but there are others, like "the distance between any part of the
vehicle and the ground is not less than 100mm."
It should all be documented in the following:
http://www.transport.sa.gov.au/pdfs/personal_transport/light_vehicles_pdfs/MR1136_Requirements_for_Lowering_or_Raising_Vehicle_Ride_Height.PDF
http://www.transport.sa.gov.au/pdfs/personal_transport/light_vehicles_pdfs/fact_sheet_track_suspen.pdf
Anyway, familiarise with the above, and call Regency Park - you may even get a straight answer.
If they abolished eyebrow height you could technically be on the tyres with 100mm clearance still, and one would think that you need some sort of clearance between guard and hub to allow for adequate suspension travel, so logically, there should still be a eyebrow height law, in my head anyway...
My V35 is the opposite - I have bucketloads more eyebrow clearance than legal/desired and my exhaust (which has been modified already to be as close to the car as possible) is still way under 100mm clearance and bottoms out on EVERYTHING :(
Pretty sure that is all that is sold in Aust'. Infact i think they are all HSPA+.
when i was looking they were about to release the 4g. that was 2 weeks ago. so wuld have been out by now..
i would have got it but im with optus!
and steve i watched that yesterday when i signed up to xda... LOL
Currently doing the 4g roll out on all existing towers at my new work, you probably won't see proper 4g Australia wide for another 12 months. They might release 4g phones now but they will probably just run at 3/3.5g
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
    • Not yet quite as bad as what we've seen a Jim Berry clutch do in an R32 GTR though when it decided to cut a chassis rail in half... Still very very gnarly and a great reason to avoid.
