Bosch EV14 1000cc ID1000 style
These are a 3/4 length injector, 14mm Oring, top feed, high impedance, UScar style plug.
Tuff Car Parts can sort you out for those Adrian
steve i want anything 1000cc that will fit under my plazmaman!! LOL
status said those side feed are highflows
  • Replies 3.6k
Posted Images
i want to convert to top feed as they are cheaper/bigger cc/easier to find.
if i can find some genuine 1000cc drop in side feeds ill get them.
its either top feeds dont fit or side feeds are hiflows or not avail!
FML
Wow the Aussie dollar is in freefall after the USA debt bailout announcement - $1.10.7 2 days ago, has just bottomed out at $1.07.0 - better buy up any parts you want from overseas now kids!
Eyebrow height is the one point, but there are others, like "the distance between any part of the
vehicle and the ground is not less than 100mm."
It should all be documented in the following:
http://www.transport.sa.gov.au/pdfs/personal_transport/light_vehicles_pdfs/MR1136_Requirements_for_Lowering_or_Raising_Vehicle_Ride_Height.PDF
http://www.transport.sa.gov.au/pdfs/personal_transport/light_vehicles_pdfs/fact_sheet_track_suspen.pdf
Anyway, familiarise with the above, and call Regency Park - you may even get a straight answer.
If they abolished eyebrow height you could technically be on the tyres with 100mm clearance still, and one would think that you need some sort of clearance between guard and hub to allow for adequate suspension travel, so logically, there should still be a eyebrow height law, in my head anyway...
My V35 is the opposite - I have bucketloads more eyebrow clearance than legal/desired and my exhaust (which has been modified already to be as close to the car as possible) is still way under 100mm clearance and bottoms out on EVERYTHING :(
Pretty sure that is all that is sold in Aust'. Infact i think they are all HSPA+.
when i was looking they were about to release the 4g. that was 2 weeks ago. so wuld have been out by now..
i would have got it but im with optus!
and steve i watched that yesterday when i signed up to xda... LOL
Currently doing the 4g roll out on all existing towers at my new work, you probably won't see proper 4g Australia wide for another 12 months. They might release 4g phones now but they will probably just run at 3/3.5g
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
