  • Replies 3.6k
Posted Images
http://www.robrobinette.com/et.htm
Using my old S15 as an example it was 1,250kg +100kg for me = 2,976lb
Power was 200rwkw = 268rwhp
Calc comes up with 12.99, which was what it did on a regular basis .... but I once got it down to 12.74 with good tyres and an awesome launch.
But that calc comes up with 12.6 for an R33 with 100kg driver at 240rwkw, which is a bit optimistic imho unless you had massively sticky tyres and the launch of a lifetime. I reckon a flat 13 is par for the course for a 240rwkw R33 with decent tyres and a decent driver.
I really hope they catch these morons and throw the book at them.
For those of you with kids out there, imagine if you had pulled over ahead of them and one of your kids opened the door at the wrong time...........I know I'd be up on charges of manslaughter
Interesting app,
It says 14.46 for my car using the cars weight (1320kg), the extra 45kg for the R33 box and the XXXkg for myself lol. Also using the figure I got from Willall Saturday (cough 156.2rwkw cough)
I don't think that is right Dion - it seems to get less accurate the higher weight the car is. There are heaps of online drag calcs, go Google some - they came up with times between 14 seconds and 13 seconds flat for my V35 depending on which one you believe. I believe it would be dead inbetween the two, personally :)
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
