  • Replies 3.6k
Posted Images
Yeah it seems anyone named Matty are genuinely a top bloke :whistling:
Who's going to this Carpark Carnival thing?? I don't think the 32 will be fixed by 5:30 sadly
I'm going.
My car is filthy as a Hanson road hooker but I can't wash it in this heat, the detergent will dry on.
I'm going.
swing past mine and we'll do a quick engine swap
pete : http://www.facebook.com/events/277445218944960/
I'll be heading down
Good to put the feet up at home, considering im technically still getting 30 bucks an hour for the next 1 hour and 4 minutes :rofl:
Its what i do Sherlock, we had stuff all on at work today with half the depot having days off before the Pt Lincoln trip, so id only have ended up stuck in the store doing f**k all LOL
If Nightcrawler is going, he can swing past and pick me up on the way :P
oh dear
Up for sale is my pride and joy! I purchased the corona 15 years ago of my Nan, who purchased the car new from Toyota in 1986. This car has been in my family since new and has cost me over $100,000 to get it to where it is today.
SERIOUS 100k
Anyone have a half inch rattle gun? I'm the lucky bastard who gets to do the wheel bearings on the missus' e36 (they're originals with 235k on them) Caliper bolts aren't budging!!
Yeah mate I have one you can borrow with sockets .... come pick it up tomorrow afternoon and you can bring back my Wax Attack :D
fixed
:rofl:
steve, not wrong with the sandown stuff. even the touring car masters it was hairy. did you see the HQ that hit the wall, did more damage to the barrier fence than the car itself :laugh:
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
