  • Replies 69
Matt, Nightcrawler has video of that last burnout of yours, along with a couple of runs if you're interested. I'm a pretty shitty photographer though, so some are better than others.
Bit more smoke will get those 540s nice and sticky. You can hear you breaking traction at every gear change in one of the vids!
Yep mate, I'm VERY keen to have a look at the vid's! Thanks for filming me :D Andy, when can I drop 'round for a look? I'd be happy for them to be posted up, if that's possible?
I agree with you Dean. I'd say the Fullboost site doesn't take into account.... shall we say... local road registered car "issues" that occur in SA (Adelaide). Whereas Mark from Pulsar Parts is only too well aware.
Sam (MiTSiCHiCK), I'm guessing you're talking about me? If so... thanks :rofl:
Andy, I can come round later tonight, if that's ok? PM me your number (have been meaning to get it for a while anyway) and I'll ring you later.
Thanks mate :D
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
