  • 1 month later...
yeah had a quick look but mine is in a s13 silvia and there is no way i can fit my hand down the front of the motor as there is no room, barely enough to see all the belts and pulleys in front. a simple front on diagram would be handy!
Screenshot taken out of the manual I downloaded a while ago.
http://screensnapr.com/e/ELKoXj.png
Belts go powersteering, aircon, alternator/waterpump
Manual I just uploaded for R33 Skyline. 23MB
http://www.mediafire...wpnk6cdrnj87cef
Tip:
Contents page is 21.
Add 20 to page number.
Example:
If page number is EN-21, type 41 in to Adobe reader
Edited by H4x
I think 3pk means 3 grooves and 4pk means 4 grooves. Also I think the bosch catalog is wrong because when I checked the part numbers on my belts one was 3pk when all the belts listed in the catalog were 4pk
Edited by H4x
absolutely perfect H4x thanks a lot! Found the diagram and the info and a whole manual as an extra on top. i have the broken belt so i can just bring that with me. The pulley i was worried about is just an idler pulley for tensioning so thats good. should be easy to replace when i put in an alloy rad.
Cheers
tom
  • 1 year later...
Sorry to bring up an old thread here guys but i was just looking at my engine after giving the car a quick wash and noticed that one of my belts seems to be not on correctly. Its the belt sitting on the top most pulley, not sure but i think its the aircon belt. Anyway, just wondering if it was possible to somehow fix that link to the r33 manual as I would find it very useful. Without getting the front bar + fan + cooler off its going to be hard for me to see where to adjust this belt. It looks like it has skipped a rib so only 3/4 of them are running on the actual pulley and the other is off the side. Any help will be muchly appreciated and i can upload a pic if needed.
Um I think theres two bolts you loosen and and another one you use to adjust it. Definetly don't unbolt the pump from the engine.
Haha yeah cheers mate. I ended up taking off the nut on the adjustment thing then removing the bolt that holds that adjusting thing in. That allowed me to get the belt loose enough to get it back on properly :))
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
