Hey all
I'm getting an upgraded turbo for my R34 but apparently its bein made from scratch its a garrett GT30. Just wondering if anyone knows If it takes a while to make and why, Its gettin made by a workshop here in perth so if anybody knows peeps who work for this shop let us know.
I've been waiting for at least 4 months now, its gettin annoying.
seriously.
https://www.sau.com.au/forums/topic/365571-turbo-building/
I forgot to say that apparently the rear housing on the origanal turbo was easily cracked by a slam of a hammer, i mean i 've heard that this workplace that is doin my turbo upgrade is expensive but does good work that isn't an issue for me i want my car to operate fine for me so i just want to know what the hell is going on, so i can continue to smoke monaro's at the lights
you know what i'mtalkin bout...............ah ha you know what it is
https://www.sau.com.au/forums/topic/365571-turbo-building/#findComment-5835170
thats the thing i dropped 3 grand on this workshop 4 the turbo for a DEPOSIT! i know its not there fault for havin to wait for this turbo company but what the f**k WHAT THE HELLS GOING ON this group who has done good work on my car before has worked well and i'm not complaining, its the turbo building company that is delaying my process
https://www.sau.com.au/forums/topic/365571-turbo-building/#findComment-5835187
Nah i didn't have to put down 3 g's thats what i wanted to do to pretty much pay off the whole thing. I'm also getting injectors and an air flow meter so at the moment i only owe bout a grand, don't know how much they will charge for the re-tune.
But all in all, this workshop is well known, they are always busy, they do charge a buck or two and i don't think the owner would risk bad reputation from installing a johnny cut corners turbo. So they always do good work.
Just wanted to know if anyone was makin these turbo's in perth, it's a garrett GT30 with a bigger rear housing, if you got these made and ready maybe someone can contact a performance workshop in Malaga.
Wink, wink, knudge, knudge.
https://www.sau.com.au/forums/topic/365571-turbo-building/#findComment-5839331
Apparenty it could be easily cracked by dropping it or slamming it with a hammer so thats why they are rebuilding a whole load of them.
But tell me when once installed in your car it is going to be dropped or hit with a hammer?
https://www.sau.com.au/forums/topic/365571-turbo-building/#findComment-5844621
so the millions of people using garrett housings are all at risk of smashed turbine housings? i've never ever seen any turbine housing of any brand break in any way..... they're the strongest part of the turbo ffs
https://www.sau.com.au/forums/topic/365571-turbo-building/#findComment-5844967
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
