car inspection
Guest neoGT-25
Hey all :)
I have found a nice A31 NISSAN CEFIRO for sale... only problem is, im in qld :D
now, before i buy her, i want to get it inspected and possibly compression tested (are compression tests worth doing & how much?) Since im in qld, i wouldent have a clue who to get it tested by and i have heard that RACV arnt very good with import inspections??
could someone please give me an idea of who to go to? web-links? phone numbers? anything like that! ;)
please please please help!! :wavey:
thanks, Cameron
ps: yes my speeling is bad, thats cost its 9:37am :)
https://www.sau.com.au/forums/topic/36562-car-inspection/
Its in QLD .. RACQ up here will do inspections, but same problem as VIC in that they might not fully know imports. It will be expensive also if you are not a member. Could try giving them a call, and they'll be able to fax you the results of the test.
Compression test is the same procedure no matter what vehicle, but its just a bitch of a bitch on the RB20's as you gotta pull a few bits off which they don't like doing.
The number for their bookings service is: (07) 3361 2700
https://www.sau.com.au/forums/topic/36562-car-inspection/#findComment-729863
`read it again u qld pig traitor
edited so he didnt think i was talking to him and being rude :(
https://www.sau.com.au/forums/topic/36562-car-inspection/#findComment-729872
lol.. you want a drift car don't you?
At $9k -- even with an autoconversions would be a good deal if you ask me.. at the time you can also get the RB25DET box put in which will be heaps stronger anyhow. I'd say at a guess the fuse would be possible as it uses a similar ATESSA system to the R32 GTR from what I've read.
https://www.sau.com.au/forums/topic/36562-car-inspection/#findComment-730180
Guest neoGT-25
i see
i will look into it!
problem is... the one i found in melb has much better bits... inc a 2way mech lsd, manual conversion, heavy duty clutch, hks pod, turbo timer, strut brace, drift wheels (16"), 2x cat back zorsts (one mild steel, one stainless) droped on springs too...
byes :(
https://www.sau.com.au/forums/topic/36562-car-inspection/#findComment-730276
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
